[GRASS-dev] [GRASS GIS] #3850: r.out.mpeg always fails because the output file name is empty
GRASS GIS trac at osgeo.org
Wed May 22 02:46:52 PDT 2019
 Reporter:  paoloz          |      Owner:  grass-dev@…
     Type:  defect          |     Status:  new
 Priority:  normal          |  Milestone:
Component:  Raster          |    Version:  svn-trunk
 Keywords:  mpeg animation  |        CPU:  Unspecified
 Platform:  Unspecified     |
 Testing r.out.mpeg using North Carolina data set, smaller subset NC
 location (nc_basic_spm_grass7)
 g.region rast=elevation
 r.out.mpeg view1=elevation at PERMANENT,elevation_shade at PERMANENT
 output=./test.mpg
 always fails with
 output=./test.mpg
 Reading raster map <elevation at PERMANENT>...\\
 Reading raster map <elevation_shade at PERMANENT>...\\
 ERROR:  Could not open output file! \\
 WARNING: mpeg_encode ERROR
 the reason is that the name of the output mpeg fie is not copied in the
 "outfile" variable, which is used to write the name of the output mpeg in
 the configuration file for "ppmtompeg"|"mpeg_encode" encoder. Therefore
 the name of the output mpeg is blank and the encoding always fail with
 "ERROR:  Could not open output file!".
 Tested with GRASS: 7.0.0, 7.4 svn (12/01/2018), 7.6.0, 7.6.1.
 Works in 6.4.6 because the variable is not empty, see lines 442-445 of
 grass-6.4.6/raster/r.out.mpeg/main.c.
 A patch to solve the problem is attached.
 Index: raster/r.out.mpeg/main.c
 --- raster/r.out.mpeg/main.c    (revisione 74509)
 +++ raster/r.out.mpeg/main.c    (copia di lavoro)
 @@ -6,6 +6,8 @@
   *               Brad Douglas <rez touchofmadness.com>, Markus Neteler
 <neteler itc.it>,
   *               Glynn Clements <glynn gclements.plus.com>, Hamish Bowman
 <hamish_b yahoo.com>,
   *               Jan-Oliver Wagner <jan intevation.de>, Paul Kelly <paul-
 grass stjohnspoint.co.uk>
 + *               Paolo Zatelli <paolo.zatelli unitn.it>
   * PURPOSE:      combines a series of GRASS raster maps into a single
 MPEG-1
   * COPYRIGHT:    (C) 1999-2006, 2011 by the GRASS Development Team
 @@ -142,6 +144,9 @@
      parse_command(viewopts, vfiles, &numviews, &frames);
 +    /* output file */
 +    strcpy(outfile, out->answer);
      r_out = 0;
      if (conv->answer)
         r_out = 1;
Ticket URL: <https://trac.osgeo.org/grass/ticket/3850>
