[GRASS-dev] git merge mess on master
Panagiotis Mavrogiorgos pmav99 at gmail.com
Thu May 23 03:22:37 PDT 2019
> On Tue, May 21, 2019 at 11:23 AM Bas Couwenberg <sebastic at xs4all.nl <https://lists.osgeo.org/mailman/listinfo/grass-dev>> wrote:
> >* On 2019-05-21 11:22, Markus Neteler wrote:
> *>* > How to revert that? Of course someone had to run into this at some
> *>* > point, so seems I "volunteered" to be the first :((
> *>>* rebase and force push.*
Vaclav Petras <wenzeslaus at gmail.com
1) There is probably a smart way to resolve it. Something along the lines
> of what Bas suggested to the situation before but you can also backup diffs
> for all you changes (if any), delete fork and delete your local clone
> and start over.
@all
Please, keep in mind that git push --force is probably the only command
that you should **never** use on main repo.
You are free to force push whatever you want on personal/private
repos/branches. Nevertheless, all commits in the shared repository should
be considered **immutable**. Please don't break this assumption. If there
is need to revert something, use git revert instead.
all the best,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190523/f80d8ce9/attachment.html>
