[GRASS-dev] [GRASS GIS] #3931: i.topo.corr: handle integer input for correction
GRASS GIS trac at osgeo.org
Mon Nov 4 23:23:00 PST 2019
 Reporter:  sbl          |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Imagery      |    Version:  svn-trunk
 Keywords:  i.topo.corr  |        CPU:  All
 Platform:  All          |
 i.topo.corr currently seems to only correct input maps of type DCELL or
 FCELL.
 It would be great if it could handle also integer maps as input. Maybe a
 quantization option, like in i.atcor would be a possibility to scale input
 from 1 - 10000 to 0.0 - 1.0 by applying the quantization factor (default
 to 1)?
 I am thinking of e.g. linked (r.external) Sentinel-2 data here, which
 comes with integer values...
 Ideally, also output should be saved as integer if input is integer,
 reapplying the quantization.
 That could save a processing step and would possibly allow to save some
 storage space.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3931>
