[GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
GRASS GIS trac at osgeo.org
Thu Nov 21 11:45:50 PST 2019
  Reporter:  neteler     |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:
 Component:  Imagery     |    Version:  svn-trunk
Resolution:              |   Keywords:  i.sentinel.import, image
       CPU:              |  collections
  Unspecified            |   Platform:  Unspecified
Comment (by sbl):
 Hm, I think I have a hunch. Can you try to
 1) delete all SAFE directories (or use a different unzip dir)
 2) run i.sentinel.import again and see if the error remains?
 If you don`t link (l-flag) the unpacked SAFE dirs should actually be
 removed automatically...
 If they are present, i.sentinel.import does not unpack again (anymore
 after my changes). If an import is interrupted it may lead to issues like
 yours...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:8>
