[GRASS-dev] [GRASS GIS] #3577: Add rename and delete of Location and Mapset in Datacatalog
GRASS GIS trac at osgeo.org
Sat Nov 30 09:05:28 PST 2019
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  normal      |  Milestone:  8.0.0
 Component:  wxGUI       |    Version:  unspecified
Resolution:              |   Keywords:  datacatalog, location, mapset,
       CPU:              |  rename, delete, move, remove, g.mapset
  Unspecified            |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:3 jidanni]:
 > And it is weird that g.mapsets.html mentions
 >  mapsets can be removed (operation=remove) **from the search path**
 > So users wonder ''"So in the world of Grass, being removed from the
 search path means the same as being unlinked from the search path -- means
 the same thing as being unlinked from the file system??" Or else why don't
 they also mention how to remove it for good?"''
 Here it only means that the mapset(s) are unlisted from the search path.
 If you have a better wording, please suggest it at
 https://github.com/OSGeo/grass/tree/master/general/g.mapsets by editing
 the file(s) and opening a pull request - that would be much appreciated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3577#comment:4>
