[GRASS-dev] Fwd: Re: [OSGeoLive] #2181: GRASS freezes when using r.import on file without projection
Markus Metz markus.metz.giswork at gmail.com
Tue Sep 3 02:17:25 PDT 2019
On Sun, Sep 1, 2019 at 8:35 AM Markus Neteler <neteler at osgeo.org> wrote:
> ________________________________
> Von: OSGeoLive <trac_osgeolive at osgeo.org>
> Gesendet: 31. August 2019 17:38:31 OESZ
> Betreff: Re: [OSGeoLive] #2181: GRASS freezes when using r.import on file
without projection
>  Reporter:  johanvdw   |       Owner:  osgeolive@…
>      Type:  defect     |      Status:  new
>  Priority:  major      |   Milestone:  OSGeoLive13.0
> Component:  OSGeoLive  |  Resolution:
>  Keywords:  grass      |
> Changes (by kalxas):
>  * keywords:   => grass
>  * cc: osgeolive@… (added)
>  * priority:  minor => major
>  * type:  task => defect
>  * milestone:   => OSGeoLive13.0
> Ticket URL: <https://trac.osgeo.org/osgeolive/ticket/2181#comment:3>
> OSGeoLive <http://live.osgeo.org/>
> self-contained bootable DVD, USB thumb drive or Virtual Machine based on
Lubuntu, that allows you to try a wide variety of open source geospatial
software without installing anything.
The reason was that r.import did not change back to the original location +
mapset by resetting GISRC. Fixed in master, relbr78, and relbr76, also for
v.import.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190903/06340552/attachment-0001.html>
