[GRASS-dev] [release planning] GRASS GIS 7.8.0 with Python3 support
Sebastiaan Couwenberg sebastic at xs4all.nl
Thu Sep 5 21:49:35 PDT 2019
On 9/6/19 5:06 AM, Vaclav Petras wrote:
> On Thu, Sep 5, 2019 at 7:50 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
> wrote:
>> On 9/5/19 12:54 PM, Markus Neteler wrote:
>>> Would shallow clone not clone the entire repo?  But we only want a
>>> subdirectory out of it.
>> `git clone --filter` may be an option, or restructure the repo with git
>> usage in mind instead of subversion, e.g. using submodules for every
>> extension which can then be checked out individually.
> Do you have experience with submodules and some suggested workflow for
> updating the code in the submodules? I'm using one submodule in one project
> and from my experience, it is extra work comparing to a single repo and it
> is quite confusing at times, but I may not be using an optimal workflow.
> What advantages would there be in submodules comparing to addons in
> individual repos with some list of modules in a file in another repo, i.e.
> something like requirements.txt or PyPI rather than repo subdirectories
> which are submodules.
I don't use submodules myself, but they would just serve to group the
individual repositories into the grass-addons repo.
Working on individual addons should be done in the working copy of that
specific repo, not the grass-addons one.
The idea is mostly to preserve a single point to fetch all for those
that want it. For everybody else there are the individual addon repos.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
