[GRASS-dev] compilation grass 7.8 - GUI not started
Markus Neteler neteler at osgeo.org
Sun Sep 22 09:56:58 PDT 2019
Hi Paulo,
On Sat, Sep 14, 2019 at 11:24 AM Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi Devs
> I just compiled/installed grass78 on my computer (Ubuntu 18.04). After
> installation and
just to be sure:
- you compiled yourself?
- you (of course) use Python 3?
> starting grass, it opens the opening window to select
> the database/location/mapset. After that, the GUI does not launch.
> Error message on the command line copied below.
> Any idea how to solve this, or is this a bug that I should report?
> Cheers, Paulo
> GRASS 7.8.1dev (exdet):~ > 11:21:16: Debug: Adding duplicate image
> handler for 'Windows bitmap file'
> 11:21:16: Debug: Adding duplicate image handler for 'Windows bitmap file'
> Traceback (most recent call last):
>   File "/usr/local/grass78/grass78/gui/wxpython/wxgui.py", line 104, in OnInit
>     from lmgr.frame import GMFrame
>   File "/usr/local/grass78/grass78/gui/wxpython/lmgr/frame.py", line
> 51, in <module>
>     from lmgr.layertree import LayerTree, LMIcons
>   File "/usr/local/grass78/grass78/gui/wxpython/lmgr/layertree.py",
> line 38, in <module>
>     from mapdisp.frame import MapFrame
>   File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/frame.py",
> line 33, in <module>
>     from mapdisp.toolbars import MapToolbar, NvizIcons
>   File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/toolbars.py",
> line 22, in <module>
>     from nviz.main import haveNviz
>   File "/usr/local/grass78/grass78/gui/wxpython/nviz/main.py", line
> 24, in <module>
>     from nviz import mapwindow
>   File "/usr/local/grass78/grass78/gui/wxpython/nviz/mapwindow.py",
> line 42, in <module>
>     from nviz.workspace import NvizSettings
>   File "/usr/local/grass78/grass78/gui/wxpython/nviz/workspace.py",
> line 23, in <module>
>     from nviz import wxnviz
>   File "/usr/local/grass78/grass78/gui/wxpython/nviz/wxnviz.py", line
> 52, in <module>
>     from grass.lib.raster3d import *
>   File "/usr/local/grass78/grass78/etc/python/grass/lib/raster3d.py",
> line 1101, in <module>
>     Rast3d_fatal_error = _variadic_function(_func,_restype,_argtypes)
> TypeError: __init__() missing 1 required positional argument: 'errcheck'
> OnInit returned false, exiting...
Does this problem persist after
make distclean
and recompilation?
Markus
