[GRASS-dev] g.extension problem on Linux
Robert Lagacé robert.lagace.qc at gmail.com
Tue Dec 1 13:16:02 PST 2020
I run Grass 7.8.4 on Ubuntu 18.04
I cannot install extension with g.extension. Follow the message from the
console :
g.extension --verbose extension=r.stream.basins
Fetching <r.stream.basins> from GRASS GIS Addons repository (be patient)...
Downloading source code for <r.stream.basins> from
<https://github.com/OSGeo/grass-addons/trunk/grass7/raster/r.stream.basins>
which is identified as 'official' type of source...
   File "/usr/lib/grass78/scripts/g.extension", line 2183, in
<module>
     sys.exit(main())
   File "/usr/lib/grass78/scripts/g.extension", line 2163, in
main
     install_extension(source=source, url=url, xmlurl=xmlurl)
   File "/usr/lib/grass78/scripts/g.extension", line 765, in
install_extension
     source=source, url=url)
   File "/usr/lib/grass78/scripts/g.extension", line 1406, in
install_extension_std_platforms
     outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
   File "/usr/lib/grass78/scripts/g.extension", line 1346, in
download_source_code
     download_source_code_official_github(url, name, outdev,
directory)
   File "/usr/lib/grass78/scripts/g.extension", line 1229, in
     url, directory], stdout=outdev) != 0:
   File "/usr/lib/grass78/etc/python/grass/script/core.py",
line 74, in call
     return Popen(*args, **kwargs).wait()
line 63, in __init__
     subprocess.Popen.__init__(self, args, **kwargs)
   File "/usr/lib/python3.6/subprocess.py", line 729, in
__init__
     restore_signals, start_new_session)
   File "/usr/lib/python3.6/subprocess.py", line 1364, in
_execute_child
     raise child_exception_type(errno_num, err_msg,
err_filename)
FileNotFoundError: [Errno 2] No such file or directory:
'svn': 'svn'
l. 1344 url :
name : r.stream.basins directory :
/tmp/grass7-rlagace-24713/tmp1htzjxu5/r.stream.basins
l. 1228  url :
directory :  /tmp/grass7-rlagace-24713/tmp1htzjxu5/r.stream.basins
(Tue Dec  1 16:03:04 2020) La commande s'est terminée (0 sec)
   The problem occours at lline 1227 with the command
if grass.call(['svn', 'export',
I had two print lines (l. 344 and l. 1228) to print variables to help debug
The name of the github is
"https://github.com/OSGeo/grass-addons/tree/master/". I change it at
line 2045 but without success.
What is the use of 'svn' in grass.call()
Thanks,
Robert Lagacé, ing., agr., prof.titulaire
Département de SGA
2425 de l'agriculture
Université Laval
Québec, Québec, G1V 0A6
courriel : robert.lagace at fsaa.ulaval.ca<mailto:robert.lagace at fsaa.ulaval.ca>
tél: (418)-656-2131 poste 402276
fax : (418)-656-3723
