[GRASS-dev] [GRASS GIS] #2895: Define dependencies for GRASS addons
GRASS GIS trac at osgeo.org
Fri Dec 18 00:57:53 PST 2020
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.8.3
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:  g.extension
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 Replying to [comment:20 wenzeslaus]:
 > > Silently installing stuff can be a bit scary...
 > Why do you think it is scary for GRASS GIS? pip, R, conda, apt, yum, ...
 all install dependencies of a package you asked for. Why this should not
 happen for GRASS GIS?
 Yes, you are right.
 So, how would we setup a requirements.txt?
 Should it contain different sections, like e.g.
 GRASS_addons
     r.area
 R_packages
     ggplot2
 Python_libraries
     rpy2>=1.1
 cmd_tools
     iconv
     cs2cs
 libraries
     libgdal-grass
 Cause the way these dependencies are installed varies a bit, with a
 dpendency_check function for each of them...
 Maybe better with a dependency json:
 "GRASS_addons": [
       "name": "r.area"
 "Python_libraries": [
       "name": "rpy2",
       "version": "1.1"
       "version_check": ">="
 In the functions we might have to think about OS specific aspects (package
 manager (incl. conda vs. pip), library names) as well as maybe versions
 (e.g. numpy>=1.17).
 Also, should a failed dependency check block the installation? Because
 that it is not a trivial task I would opt for a warning rather than an
 error message in case of missing or unresolved dependencies...
 Lastly, should a dependency check function go into ''g.extension'' or into
 the python library (script or pygrass). In the python lib it could be used
 by AddOn devs at runtime (e.g. if it takes a json formated string or
 dict)...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2895#comment:21>
