[GRASS-dev] Source code layout reorganization for G8
Vaclav Petras wenzeslaus at gmail.com
Mon Jun 8 18:34:34 PDT 2020
Hi Maris,
On Tue, Jun 2, 2020 at 5:34 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello list,
> as G8 release is a great opportunity to break things, we could
> reorganize our source code directory layout.
Well, technically, source code layout is generally not part of an API and
we don't promote it that way, so changing it anytime shouldn't be a
problem. Practically, there might be build and packaging scripts and local
patches people use which may break, but perhaps minor versions are a good
match for this work too.
> At the moment we have
> docker together with documentation and library intermingled with
> MS-Windows for MacOSX. Bringing to a separate thread from "where to
> make compiling instructions available"
> https://www.mail-archive.com/grass-dev@lists.osgeo.org/msg59974.html
Even just getting the "module families" from the root dir would help. Plus
there is couple of issues with the current include, lib/python, and
gui/wxpython directories.
> I have created an initial proposal page in Trac (linked to GRASS 8
> planning page): https://trac.osgeo.org/grass/wiki/G8SourceLayout
> Feel free to express your opinion — is it worth? How the new directory
> layout should look like? Any technical restrictions?
I have extended the page couple of days ago.
> Yes, it would break history, scripts, Make files = no fun. But if we
> don't do it now, we'll be stuck till G9 release.
Other things like splitting into multiple files, formatting, or even moving
things around also make searching history more complicated and I think this
fits into the line with things which are worth it.
A lot of the changes is independent, so that makes it simpler, but having
an overall vision where these would fall in is helpful.
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200608/2dbe293b/attachment.html>
