[GRASS-dev] OSGeo4W winGRASS 7.8.2 needs rebuild due to PROJ upgrade? or a python issue?
Helmut Kudrnovsky hellik at web.de
Sun Mar 1 02:13:54 PST 2020
Helmut Kudrnovsky wrote
> Hi,
> just opened OSGeo4W winGRASS 7.8.2 in the OSGeo4W environment. it just
> worked up to a few days ago.
> build information:
> C:\>g.version -breg
> version=7.8.2
> date=2019
> revision=3900fb114
> build_date=2019-12-11
> build_platform=x86_64-w64-mingw32
> build_off_t_size=8
>  ./configure  --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
> --with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
> --prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
> --includedir=/c/OSGeo4W64/include --without-x --with-cxx --enable-shared
> --enable-largefile --with-fftw --with-freetype
> --with-freetype-includes=/mingw64/include/freetype2
> --with-proj-share=/c/OSGeo4W64/share/proj
> --with-proj-includes=/c/OSGeo4W64/include
> --with-proj-libs=/usr/src/grass782/mswindows/osgeo4w/lib --with-postgres
> --with-postgres-includes=/c/OSGeo4W64/include
> --with-postgres-libs=/usr/src/grass782/mswindows/osgeo4w/lib
> --with-gdal=/usr/src/grass782/mswindows/osgeo4w/gdal-config
> --with-geos=/usr/src/grass782/mswindows/osgeo4w/geos-config --with-sqlite
> --with-sqlite-includes=/c/OSGeo4W64/include
> --with-sqlite-libs=/usr/src/grass782/mswindows/osgeo4w/lib --with-regex
> --with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
> --with-bzlib
> --with-liblas=/usr/src/grass782/mswindows/osgeo4w/liblas-config
> libgis_revision=00000
> libgis_date="?"
> proj=6.2.1 <=
> gdal=3.0.2
> geos=3.8.0
> sqlite=3.29.0
> PROJ was upgraded in the OSGeo4W framework a few days ago:
> C:\>proj --version
> Rel. 6.3.1, February 10th, 2020
> not sure it's the reason for following error in the console:
> C:\>Traceback (most recent call last):
>   File "C:\OSGEO4~1\apps\Python37\lib\ctypes\__init__.py", line 97, in
> CFUNCTYPE
>     return _c_functype_cache[(restype, argtypes, flags)]
> KeyError: (
> <class 'ctypes.c_long'>
> <class
> 'grass.lib.ctypes_preamble.String'>
> ,), 1)
> During handling of the above exception, another exception occurred:
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\wxgui.py", line 105,
> in
> OnInit
>     from lmgr.frame import GMFrame
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py", line
> 51,
> in
> <module>
>     from lmgr.layertree import LayerTree, LMIcons
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\layertree.py",
> line
> 38, in
> <module>
>     from mapdisp.frame import MapFrame
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\frame.py",
> line
> 33, in
> <module>
>     from mapdisp.toolbars import MapToolbar, NvizIcons
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\toolbars.py",
> line 22, in
> <module>
>     from nviz.main import haveNviz
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\main.py", line
> 24,
> in
> <module>
>     from nviz import mapwindow
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\mapwindow.py",
> line
> 42, in
> <module>
>     from nviz.workspace import NvizSettings
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\workspace.py",
> line
> 23, in
> <module>
>     from nviz import wxnviz
>   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\wxnviz.py", line
> 51, in
> <module>
>     from grass.lib.gis import *
>   File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\gis.py", line
> 475, in
> <module>
>     ('checker', CFUNCTYPE(UNCHECKED(c_int), String)),
>   File "C:\OSGEO4~1\apps\Python37\lib\ctypes\__init__.py", line 99, in
> CFUNCTYPE
>     class CFunctionType(_CFuncPtr):
> TypeError: item 1 in _argtypes_ passes a union by value, which is
> unsupported.
> OnInit returned false, exiting...
> or it could be a python 3 update yesterday:
> http://download.osgeo.org/osgeo4w/x86_64/release/python3/python3-core/?C=M&O=A
> python3-core-3.7.6-1.tar.bz2	10M	2020-Feb-29 23:07
> C:\>python
> Python 3.7.6 (tags/v3.7.6:43364a7ae0, Dec 19 2019, 00:42:30) [MSC v.1916
> 64
> bit (AMD64)] on win32
> Type "help", "copyright", "credits" or "license" for more information.
or just
https://github.com/davidjamesca/ctypesgen/issues/77#issuecomment-593023266
also now in winGRASS?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
