[GRASS-dev] Automatic/CI compilation on macOS
Vaclav Petras
wenzeslaus at gmail.com
Thu Mar 5 12:38:26 PST 2020
On Thu, Mar 5, 2020 at 1:52 PM Rainer M Krug <Rainer at krugs.de> wrote:
> On 5 Mar 2020, at 17:53, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Mar 5, 2020 at 11:37 AM Rainer M Krug <Rainer at krugs.de> wrote:
>> OK - one step closer to success. Now I just have to know the location
>> where the data for the tests can be downloaded from (I guess).
> Everything is in the repo, well, it needs to be, I guess the only question
> is where in the repo, so:
> https://github.com/GRASS-GIS/grass-gis-experimental-ci/blob/homebrew-osgeo4mac/test_thorough.sh
>> Please check the log to at
>> https://github.com/GRASS-GIS/grass-gis-experimental-ci/runs/487969965?check_suite_focus=true for
>> the *Basic test* and the *Thorough test*. I will look at the return code
>> later, when the tests are running.
> The problem there is probably a bad/missing path to PROJ db. I think it
> complains during the configuration already, so perhaps correct
> --with-proj-share will fix it. The runtime way of setting it is PROJ_LIB
> environmental variable. You can try something along these lines.
> I am trying to find the file `proj.db` but can’t find it - can you give me
> any indication, where it can be found in Linux (home-brew should use
> similar locations)?
Often it is in `/usr/share/proj`. Now you can find things like that in the
Docker/Singularity/Vagrant configurations included in GRASS GIS source code
or in the CIs, e.g., here:
https://github.com/GRASS-GIS/grass-gis-experimental-ci/blob/master/build.sh#L39
>> Rainer
>> On 5 Mar 2020, at 16:28, Rainer M Krug <Rainer at krugs.de> wrote:
>> On 5 Mar 2020, at 16:22, Rainer M Krug <Rainer at krugs.de> wrote:
>> On 5 Mar 2020, at 14:52, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Thu, Mar 5, 2020 at 4:27 AM Rainer M Krug <Rainer at krugs.de> wrote:
>>> OK - found the ci.
>>> The formula installs, but I get a warning at the end, which results in a
>>> warning, which is than interpreted as an error. The warning (which I also
>>> get locally) is the following:
>>> If it is the case that you can change the shebang at the beginning of
>>> he script to enforce Python 3 usage.
>>> #!/usr/bin/env python
>>> Should be changed into
>>> #!/usr/bin/env python3
>>> I suspect that this needs to be done in GRASS itself?
>> Hi, thanks for looking into this. 7.8.2 (and also above) has python3
>> everywhere in shebang. See e.g.:
>> $ grep -Irn "/usr/bin/env python[^3]"
>> scripts/g.extension/g.extension.py:1059:
>> "#!/usr/bin/env python\n",
>> scripts/g.extension/g.extension.py:1308:
>> # (these two are in fact code which is doing the replacement to python3)
>> Can you please investigate locally where the message coming from?
>> The message comes from the formula as a Caveat. I *think* it is always
>> displayed. But at the moment, I am not to sure where the error code comes
>> from, as I get an error code at the end of the brew command of 0 locally.
>> I will look into this.
>> Please ignore the following about the checkout.
>> Found it.
>> Do you know, why there is a
>> - uses: actions/checkout at v2
>> In the action?
>> It seems, that it will be executed last, and there is no checkout needed.
>> Rainer
>> Vaclav
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
>> (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Orcid ID: 0000-0002-7490-0066
>> Department of Evolutionary Biology and Environmental Studies
>> University of Zürich
>> Office Y34-J-74
>> Winterthurerstrasse 190
>> 8075 Zürich
>> Switzerland
>> Office: +41 (0)44 635 47 64
>> Cell: +41 (0)78 630 66 57
>> email: Rainer.Krug at uzh.ch <Rainer.Krug at uzh.ch>
>> Rainer at krugs.de
>> Skype: RMkrug
>> PGP: 0x0F52F982
>> Office Y34-J-74
>> 8075 Zürich
>> Switzerland
>> Rainer at krugs.de
>> Skype: RMkrug
>> PGP: 0x0F52F982
>> Office Y34-J-74
>> 8075 Zürich
>> Switzerland
>> Rainer at krugs.de
>> Skype: RMkrug
>> PGP: 0x0F52F982
> Office Y34-J-74
> 8075 Zürich
> Switzerland
> Rainer at krugs.de
> Skype: RMkrug
> PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/c12eb7a1/attachment.html>
