[GRASS-dev] ZSTD compression error on Windows
Helmut Kudrnovsky hellik at web.de
Fri May 1 04:09:38 PDT 2020
Martin Landa wrote
> Hi,
> I have problem to read raster data created on Linux machine.
> With the same data I am getting on Windows error below.
> WARNING: ZSTD compression error -14: Unsupported frame parameter
> ERROR: Error uncompressing fp raster data for row 30 of
> <MASK>
> : error code -1
> But ZSTD seems to be enabled on Windows...
> C:\>g.version -b
> GRASS 7.9.dev (2020)
>  ./configure  --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
> --with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
> --prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
> --includedir=/c/OSGeo4W64/include --without-x --with-cxx
> --enable-shared --enable-largefile --with-fftw --with-freetype
> --with-freetype-includes=/mingw64/include/freetype2
> --with-proj-share=/c/OSGeo4W64/share/proj
> --with-proj-includes=/c/OSGeo4W64/include
> --with-proj-libs=/usr/src/grass79/mswindows/osgeo4w/lib
> --with-postgres --with-postgres-includes=/c/OSGeo4W64/include
> --with-postgres-libs=/usr/src/grass79/mswindows/osgeo4w/lib
> --with-gdal=/usr/src/grass79/mswindows/osgeo4w/gdal-config
> --with-geos=/usr/src/grass79/mswindows/osgeo4w/geos-config
> --with-sqlite --with-sqlite-includes=/c/OSGeo4W64/include
> --with-sqlite-libs=/usr/src/grass79/mswindows/osgeo4w/lib --with-regex
> --with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
> --with-bzlib
> --with-liblas=/usr/src/grass79/mswindows/osgeo4w/liblas-config
> Any idea? Thanks, Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Maybe different zstd versions in linux and windows? Maybe we should update
zstd in osgeo4w?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
