[GRASS-dev] Make terminal window optional?
Stefan Blumentrath Stefan.Blumentrath at nina.no
Thu Sep 10 23:57:12 PDT 2020
Hei,
Not strictly limited to the details in this discussion, but somewhat related:
Having the terminal as an “opt in” sounds reasonable to me, esp. with the new UI/startup design. Experienced users can always start terminal deliberately. And if user prefrences can still get picked up from the .grassrc file that would be nice. So, even if I work a lot like Vero does during teaching, I am positive to this change. And Option 2 sounds fine.
Between the lines I somehow read the idea to make the GUI a bit more RStudio / Spyder like. That sounds very interesting to me as it could actually simplify the GUI layout a bit. We have a Console in the GUI (with limited functionality) and a Python tab. I understand that this would be a bigger issue and involve significantly more work. Maybe a GSoC project for 2021?
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Luca Delucchi
Sent: torsdag 10. september 2020 23:25
To: Vaclav Petras <wenzeslaus at gmail.com>
Cc: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] Make terminal window optional?
On Sun, 6 Sep 2020 at 05:06, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Dear all,
Hi Vaclav,
> 2. Remove the terminal from desktop launchers so that GRASS GIS starts without the terminal when started in the GUI way. When a user starts GRASS GIS using a command from an existing terminal, there is no change from the current behavior: a (sub-)shell is started and possibly GUI launches.
this is fine for me
> Best,
> Vaclav
ciao
Luca
www.lucadelu.org
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
