[GRASS-dev] Min. req. of programming language standard support, GRASS GIS 8
Markus Metz
markus.metz.giswork at gmail.com
Fri Feb 5 11:29:10 PST 2021
On Thu, Feb 4, 2021 at 5:35 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Similarly to the GDAL and PROJ issue where I don't think it is necessary
to have GRASS C89/C++98 compliant when you need C++11 for GDAL anyway.
The C code of GRASS master is currently compatible with a lot of GDAL and
PROJ versions, also GDAL 1.xand PROJ 4.8.x which most likely do not require
C++11 or C99. If we want to keep this compatibility, we need to stick with
the lower C and C++ standards. Related to the question which currently
supported production environments we want to support.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210205/9dd93e59/attachment.html>
