[GRASS-dev] grass-session integration into core
Markus Neteler neteler at osgeo.org
Tue Jun 8 23:55:05 PDT 2021
Hi devs,
Vaclav Petras <notifications at github.com> schrieb am Mi., 9. Juni 2021,
05:22:
> ...anyway, I think the ultimate fix is to build usable images from GRASS
> source code without a 3rd party library which is not an official
> dependency. Either GRASS needs grass-session to work and then it should be
> part of the source code or GRASS should be fixed to work without it.
>> You are receiving this because you modified the open/close state.
> Reply to this email directly, view it on GitHub
> <https://github.com/OSGeo/grass/pull/1624#issuecomment-857341278>,
Following this comment I'd like to open the discussion: also in my view we
need to make grass-session part of core. And that in a way that it can be
split out easily as a pip package or whatever appropriate.
Opinions are welcome!
Best
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210609/864c914d/attachment.html>
