[GRASS-dev] GSoC 2021: Week 2: First steps towards a new GRASS GIS Single-Window GUI
Linda Kladivová L.Kladivova at seznam.cz
Sun Jun 20 09:24:27 PDT 2021
Hello everyone,
I am sending my Week 2 report (June 14 - June 20), you can also find it in
the project wiki: https://trac.osgeo.org/grass/wiki/GSoC/2021/
SingleWindowLayout#Week2
(https://trac.osgeo.org/grass/wiki/GSoC/2021/SingleWindowLayout#Week2).
What did I complete during the second week?
I focused on the GUI refactoring. In order to add Map Display to the
notebook widget, we need to have it in the form of wx.Panel. I divided the
work into several steps:
   * I changed the way of creating the Map Display status bar (which is now
   independent of the parent widget) [1]. However, this PR caused the bug
   related to the workspace saving [2] which I corrected ASAP [3].
   * Meantime, I started more complex PR changing the way the Map Display is
   built (see ​(https://github.com/OSGeo/grass/pull/1656)[4]). The core lies
   in adding the intermediate wx.Panel widget. This PR aims at more general
   Map Display refactoring, do not change the code in the Single-Window
   parallel environment - adapting the S-W GUI is planned to be another step
   forward.
What am I going to achieve for next week?
   * I plan to finish the refactoring of Map Display related stuff (see [4])
   and utilize it in the Single-Window GUI environment. It will lead to a
   new Map Display notebook widget (composed of wx.Panel Map Displays). This
   notebook will be then used as the content pane.
Is there any blocking issue?
No, it is not.
[1] https://github.com/OSGeo/grass/pull/1646
(https://github.com/OSGeo/grass/pull/1646)
[2] https://github.com/OSGeo/grass/issues/1657
(https://github.com/OSGeo/grass/issues/1657)
[3] https://github.com/OSGeo/grass/pull/1665
(https://github.com/OSGeo/grass/pull/1665)
[4] ​https://github.com/OSGeo/grass/pull/1656
Any suggestions are welcome. :-)
Best wishes,
Linda Kladivova
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210620/69190347/attachment.html>
