[GRASS-dev] Failing addon releasebranch_7_8 (Python 3.6) pipeline
    Stefan Blumentrath
    Stefan.Blumentrath at nina.no
    Wed Mar 24 02:59:06 PDT 2021
See also: https://github.com/OSGeo/grass-addons/pull/488
That does not really solve the issue at hand. Unstable tests seem very unfortunate to me. But the PR contributes to improved addon testing and increases success rate....
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Vaclav Petras
Sent: onsdag 24. mars 2021 02:15
To: Markus Neteler <neteler at osgeo.org>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Failing addon releasebranch_7_8 (Python 3.6) pipeline
On Mon, Mar 22, 2021 at 7:39 AM Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
Executing <python3 -m grass.gunittest.main --grassdata /home/runner
--location nc_spm_full_v2alpha2 --location-type nc --min-success 60>
generate_manpage_images from ./vector/v.stream.order failed
test_stream_order from ./vector/v.stream.order failed (2 tests failed)
test_pygbif_import from ./vector/v.in.pygbif failed (3 tests failed)
test_v_db_pyupdate from ./vector/v.db.pyupdate failed (2 tests failed)
r3_forestfrag_trivial from ./raster3d/r3.forestfrag failed (1 test failed)
test_whatcsv from ./temporal/t.rast.whatcsv failed (1 test failed)
test_whataggr from ./temporal/t.rast.what.aggr failed (6 tests failed)
test_gpot from ./raster/r.green/r.green.gshp/libgshp failed
test_numbers from ./raster/r.sample.category failed
r_extract_test from ./raster/r.extract failed (2 tests failed)
r_object_geometry_test from ./raster/r.object.geometry failed (2 tests failed)
test_base_resolution from ./raster/r.in.pdal failed
r_forestfrag_trivial from ./raster/r.forestfrag failed (1 test failed)
r_forestfrag_xy from ./raster/r.forestfrag failed (1 test failed)
test_append from ./raster/r.learn.ml2 failed
Looking at all commits [1], it fails only sometimes although it seems really only in the releasebranch_7_8 (Python 3.6) combo. By comparing the lists of failing tests in Meld, I identified that the fluctuating test is r_forestfrag_xy from ./raster/r.forestfrag failed. Resolving that, or fixing any other failing test (test file to be exact) will stabilize the success rate above 60% and resolve this issue without lowering the rate or introducing separate success rates for each combo at this point.
Does anyone know why it fails in the releasebranch_7_8 (Python 3.6)
pipeline but works in releasebranch_7_8 (Python 3.8)?
This would be good of course good to investigate...
[1] https://github.com/OSGeo/grass-addons/commits/master<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fcommits%2Fmaster&data=04%7C01%7C%7C5668676861a8424f7d2e08d8ee6258cb%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637521453477292909%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=va%2FJ88vy182%2B%2BNlgwfXh6aF5ZylwOZZC7Q8H%2F6i3enY%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210324/6a29f85b/attachment.html>
