[GRASS-dev] Failing addon releasebranch_7_8 (Python 3.6) pipeline
Markus Neteler neteler at osgeo.org
Sun Mar 28 13:45:12 PDT 2021
On Sun, Mar 28, 2021 at 4:55 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Not an immediate issue after the dependency related PR 488 is merged, but for actually fixing the failing tests, it is worth noting that now also the 7.8 runs can be examined in core and in addons through artifacts. For master branch (in both core and addons), it just depends what you find more convenient, HTML from artifact, text output in the Checks view, or the same text output but through View raw logs.
This is a great help - thanks for that!
Markus
