[GRASS-dev] [release planning] GRASS GIS 8: create new release branch
Markus Neteler neteler at osgeo.org
Sat May 15 06:38:38 PDT 2021
Denis,
On Fri, May 14, 2021 at 10:12 PM Denis Ovsienko <denis at ovsienko.info> wrote:
> On Fri, 14 May 2021 17:09:42 +0200
> Markus Neteler <neteler at osgeo.org> wrote:
> > Now, the question is, also to avoid excessive cherry-picking of fixes
> > and changes from master (to be called 8.1 then), which of the open PR
> > may be merged soon?
#1237: parser: fixup more messages
--> looks good, will you merge it?
#1421 r.geomorphon: fix landform category names
--> I have added a comment, related to the HTML page content
#1569 (fixes #1420) r.in.poly: do not try to use stdin as input
#1570 (fixes #1355) r.geomorphon: remove multires-specific code
--> will you merge them?
> These are all trivial bugfixes.
>     Denis Ovsienko
Markus
