[GRASS-dev] r.watershed fails on WIN10 with g_spawn: unable to execute command (bug #1579)
Helmut Kudrnovsky hellik at web.de
Fri May 21 12:51:44 PDT 2021
hi devs,
any idea about that one?:
https://github.com/OSGeo/grass/issues/1579
r.watershed --o --q -abs elevation=DEM at PERMANENT hbasin=slu_r thresh=1169
WARNING: G_spawn: unable to execute command <==
WARNING: Subprocess failed with exit code -1073741511  <==
integer/buffer overflow?
though I've tested the used DEM (link is in the ticket) on several win 10 boxes; I can't reproduce this error.
ciao
helli
