[GRASS-dev] ParallelModuleQueue freezes...
Anna Petrášová kratochanna at gmail.com
Fri May 28 07:36:14 PDT 2021
On Fri, May 28, 2021 at 10:02 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Some more context.
> The t.rast.neighbors test seems to work with the current dev version
> "2048e1016" from 2021-05-19T09:38:49+00:00
> It fails however, with 7.8.5 from 2020-12-22T15:55:09+00:00 and an older
> development version "35edbf7dc"
> from 2020-06-03T16:03:52+00:00
> So, maybe one or more of the recent changes need backporting?
> https://github.com/OSGeo/grass/commits/master/python/grass/pygrass/modules/interface/module.py
This one:
https://github.com/OSGeo/grass/pull/1407
The reason I didn't backport it was there has been a small change in API
to make it work. But Python3 support is probably a good reason to backport
it.
> In the 7_8 release branch, the latest change is from May 2019:
> https://github.com/OSGeo/grass/commits/releasebranch_7_8/lib/python/pygrass/modules/interface/module.py
> Hope that helps identifying a solution?
> Cheers
> Stefan
> -----Original Message-----
> From: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> Sent: torsdag 27. mai 2021 23:09
> To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; Luca Delucchi <
> lucadeluge at gmail.com>; Anna Petrášová <kratochanna at gmail.com>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org>
> Subject: RE: [GRASS-dev] ParallelModuleQueue freezes...
> See:
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fpull%2F1600&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5yfxG5gjlYlzgJn6yTP9zbUk7GE1JdcYPxWIQFwUK%2Fo%3D&reserved=0
> Please test.
> Unittests for t.rast.neighbors should work again with this small change...
> From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Stefan
> Blumentrath
> Sent: torsdag 27. mai 2021 08:19
> To: Luca Delucchi <lucadeluge at gmail.com>; Anna Petrášová <
> Subject: Re: [GRASS-dev] ParallelModuleQueue freezes...
> The combination ParallelModuleQueue and MultiModule is used in
> t.rast.neighbors:
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ft.rast.neighbors.py&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5QyN%2FR1cXgoWWGS2lgjKi8%2BeLX77w37bfMQzcP6O4bM%3D&reserved=0
> The testsuite of that module is deactivated for Python > 2.
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ftestsuite%2Ftest_neighbors.py&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=nQTdDIGmefI6F37zdjhyMDBYUrIxVaC%2FiA5FzeUK2KU%3D&reserved=0
> If you activate it by commenting out line 15. You will see the behavior...
> Thanks for looking into this!
> Cheers
> Stefan
> From: Luca Delucchi <lucadeluge at gmail.com>
> Sent: torsdag 27. mai 2021 06:07
> To: Anna Petrášová <kratochanna at gmail.com>
> Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; GRASS developers
> On Thu, 27 May 2021 at 04:07, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > Could you provide an example that is failing? The doctests are running
> for me. I spent some time fixing it a couple months ago. I use Python 3.6,
> I wonder if newer Python would cause some issues.
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=KT5h55J89LLXhK7uEujAmIwfksjPGyXEy2u7gYIc2Ns%3D&reserved=0
> line 544, the commented lines are not working for me..
> If you want to try t.vi just comment line 543 and uncomment the following
> lines..
> > Anna
> ciao
> Luca
> https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=hM8CpSgjw7SFjGKxM9SFfWI3G8U3nr8eeCqedZORdso%3D&reserved=0
> grass-dev mailing list
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-dev&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IwP5QxiLzELTGrr393lqAWrlWRhBVg%2FbOhrz9lBHMkw%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210528/da32dce3/attachment-0001.html>
