[GRASS-dev] multiprocessing problem
Luca Delucchi lucadeluge at gmail.com
Fri Apr 8 01:45:56 PDT 2022
On Fri, 8 Apr 2022 at 09:14, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> Hi Luca,
Hi Moritz,
> Just two brainstorming ideas:
> - From a rapid glance at the code it seems to me that you create a separate worker for each row in the raster. Correct ? AFAIR, spawning workers does create quite a bit of overhead. Depending on the row to column ratio of your raster, maybe you would be better off sending larger chunks to workers ?
right now I creating a worker for each pixel to be checked against all
the other pixels, yes it could be and idea to send larger chunks, I
could split the array vertically according to the number of processor
> - Depending on the number of parallel jobs, disk access can quickly become the bottleneck on non parallelized file systems. So it would be interesting to see if using fewer processes might actually speed up things. Then it is a question of finding the equilibrium.
ok, this make sense
thanks for your support
> Moritz
ciao
Luca
www.lucadelu.org
