[GRASS-dev] hi
Daniel Torres nobeeakon at gmail.com
Mon Aug 1 06:55:26 PDT 2022
Thanks guys,
I'm ok with starting on the website.
About the search, in Hugo website they suggest a couple of methods
https://gohugo.io/tools/search/ , have those been tried?
On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Daniel,
> Welcome! Besides what Vashek pointed out, if you feel comfortable starting
> with something for the website, we are missing a search engine there. There
> were a couple of attempts in the past but none of them worked fully as
> expected. Have a look at the PRs here:
> https://github.com/OSGeo/grass-website/pulls
> Best,
> Vero
> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
> escribió:
>> Hi Daniel,
>> Welcome. That sounds great. For Python, check this presentation I'm
>> preparing for FOSS4G where are I describe how to do good PRs which fix
>> coding standards and the load of tools which can be applied:
>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>> JavaScript at this point means starting with your own idea which may or
>> may not be what you are looking for. Website is certainly one option.
>> I would really like to see changes in the documentation (aka HTML manual
>> pages):
>> https://grass.osgeo.org/grass83/manuals/
>> ...but that's certainly "bring your own idea." It likely involves some
>> HTML and CSS design, but perhaps there is something more functional that
>> can be done. An alternative to this is migrating to Sphinx first, but
>> that's just a thought from the past.
>> Now when I think about it, the full JavaScript checks in Super-Liner are
>> not enabled, so that's perhaps a small JavaScript task to tackle before
>> starting a bigger project (that's up to you!).
>> Let me know if there is any other info which would be helpful.
>> Best,
>> Vaclav
>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com> wrote:
>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>> contribute to the project, as I find it really nice. I have experience with
>>> JS and front end stuff, but also with Python.
>>> Happy to contribute, but don't really know where to start. (Maybe
>>> something on the website side?)
>>> Cheers,
>>>   Daniel
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/21167e6a/attachment.htm>
