[GRASS-dev] hi
Daniel Torres nobeeakon at gmail.com
Mon Aug 1 10:51:27 PDT 2022
thanks Veronica, then I'll  try with the ones suggested in Hugo website
(is there another communication method you guys use, like Slack, discord or
something like kind of more direct or  quick questions and stuff? )
On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hello Daniel,
> IIRC, I suggested using something similar to what wowchemy (former hugo
> academic) has, but the path chosen was different. Paulo, also made a
> suggestion, but I didn't have the time to try, honestly. I think it's all
> in the PRs and probably this issue too:
> https://github.com/OSGeo/grass-website/issues/19
> Vero
> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
> escribió:
>> Thanks guys,
>> I'm ok with starting on the website.
>> About the search, in Hugo website they suggest a couple of methods
>> https://gohugo.io/tools/search/ , have those been tried?
>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hi Daniel,
>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>> starting with something for the website, we are missing a search engine
>>> there. There were a couple of attempts in the past but none of them worked
>>> fully as expected. Have a look at the PRs here:
>>> https://github.com/OSGeo/grass-website/pulls
>>> Best,
>>> Vero
>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
>>> escribió:
>>>> Hi Daniel,
>>>> Welcome. That sounds great. For Python, check this presentation I'm
>>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>>> coding standards and the load of tools which can be applied:
>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>> JavaScript at this point means starting with your own idea which may or
>>>> may not be what you are looking for. Website is certainly one option.
>>>> I would really like to see changes in the documentation (aka HTML
>>>> manual pages):
>>>> https://grass.osgeo.org/grass83/manuals/
>>>> ...but that's certainly "bring your own idea." It likely involves some
>>>> HTML and CSS design, but perhaps there is something more functional that
>>>> can be done. An alternative to this is migrating to Sphinx first, but
>>>> that's just a thought from the past.
>>>> Now when I think about it, the full JavaScript checks in Super-Liner
>>>> are not enabled, so that's perhaps a small JavaScript task to tackle before
>>>> starting a bigger project (that's up to you!).
>>>> Let me know if there is any other info which would be helpful.
>>>> Best,
>>>> Vaclav
>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>> wrote:
>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>> JS and front end stuff, but also with Python.
>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>> something on the website side?)
>>>>> Cheers,
>>>>>   Daniel
>>>>> _______________________________________________
>>>>> grass-dev mailing list
>>>>> grass-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/e8b6e2b8/attachment.htm>
