[GRASS-dev] hi
Daniel Torres nobeeakon at gmail.com
Mon Aug 1 11:17:21 PDT 2022
Venga, muchas gracias Veronica.
Nice, thanks, I'll open a discussion. I mean, I'm just joining and possibly
there are some downsides of doing so and most probaly it has already been
discussed, but I think it would be useful to ease the communication.
On Mon, Aug 1, 2022 at 12:58 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hola Daniel,
> None of those at time, but you could open a new discussion in github
> (though that is in the main grass repo...)
> Vero
> El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com> escribió:
>> thanks Veronica, then I'll  try with the ones suggested in Hugo website
>> (is there another communication method you guys use, like Slack, discord
>> or something like kind of more direct or  quick questions and stuff? )
>> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hello Daniel,
>>> IIRC, I suggested using something similar to what wowchemy (former hugo
>>> academic) has, but the path chosen was different. Paulo, also made a
>>> suggestion, but I didn't have the time to try, honestly. I think it's all
>>> in the PRs and probably this issue too:
>>> https://github.com/OSGeo/grass-website/issues/19
>>> Vero
>>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>>> escribió:
>>>> Thanks guys,
>>>> I'm ok with starting on the website.
>>>> About the search, in Hugo website they suggest a couple of methods
>>>> https://gohugo.io/tools/search/ , have those been tried?
>>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
>>>> wrote:
>>>>> Hi Daniel,
>>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>>> starting with something for the website, we are missing a search engine
>>>>> there. There were a couple of attempts in the past but none of them worked
>>>>> fully as expected. Have a look at the PRs here:
>>>>> https://github.com/OSGeo/grass-website/pulls
>>>>> Best,
>>>>> Vero
>>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
>>>>> escribió:
>>>>>> Hi Daniel,
>>>>>> Welcome. That sounds great. For Python, check this presentation I'm
>>>>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>>> coding standards and the load of tools which can be applied:
>>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>>> JavaScript at this point means starting with your own idea which may
>>>>>> or may not be what you are looking for. Website is certainly one option.
>>>>>> I would really like to see changes in the documentation (aka HTML
>>>>>> manual pages):
>>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>>> ...but that's certainly "bring your own idea." It likely involves
>>>>>> some HTML and CSS design, but perhaps there is something more functional
>>>>>> that can be done. An alternative to this is migrating to Sphinx first, but
>>>>>> that's just a thought from the past.
>>>>>> Now when I think about it, the full JavaScript checks in Super-Liner
>>>>>> are not enabled, so that's perhaps a small JavaScript task to tackle before
>>>>>> starting a bigger project (that's up to you!).
>>>>>> Let me know if there is any other info which would be helpful.
>>>>>> Best,
>>>>>> Vaclav
>>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>>> wrote:
>>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>>> JS and front end stuff, but also with Python.
>>>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>>>> something on the website side?)
>>>>>>> Cheers,
>>>>>>>   Daniel
>>>>>>> _______________________________________________
>>>>>>> grass-dev mailing list
>>>>>>> grass-dev at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/7c611e11/attachment-0001.htm>
