[GRASS-dev] hi
Vaclav Petras wenzeslaus at gmail.com
Mon Aug 1 11:58:01 PDT 2022
...but I should add: Let's see what works.
On Mon, 1 Aug 2022 at 14:56, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> There is no difference in discussing things in the PR or issue versus in a
> Discussion in terms of notifications, no? If it is about development, it
> should be part of this mailing list or the PRs/issues in the relevant repo.
> I don't see what Discussion would add here. ...that's of course different
> from considering the more "chatty" channels.
> On Mon, 1 Aug 2022 at 14:17, Daniel Torres <nobeeakon at gmail.com> wrote:
>> Venga, muchas gracias Veronica.
>> Nice, thanks, I'll open a discussion. I mean, I'm just joining and
>> possibly there are some downsides of doing so and most probaly it has
>> already been discussed, but I think it would be useful to ease the
>> communication.
>> On Mon, Aug 1, 2022 at 12:58 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hola Daniel,
>>> None of those at time, but you could open a new discussion in github
>>> (though that is in the main grass repo...)
>>> Vero
>>> El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com>
>>> escribió:
>>>> thanks Veronica, then I'll  try with the ones suggested in Hugo website
>>>> (is there another communication method you guys use, like Slack,
>>>> discord or something like kind of more direct or  quick questions and
>>>> stuff? )
>>>> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
>>>> wrote:
>>>>> Hello Daniel,
>>>>> IIRC, I suggested using something similar to what wowchemy (former
>>>>> hugo academic) has, but the path chosen was different. Paulo, also made a
>>>>> suggestion, but I didn't have the time to try, honestly. I think it's all
>>>>> in the PRs and probably this issue too:
>>>>> https://github.com/OSGeo/grass-website/issues/19
>>>>> Vero
>>>>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>>>>> escribió:
>>>>>> Thanks guys,
>>>>>> I'm ok with starting on the website.
>>>>>> About the search, in Hugo website they suggest a couple of methods
>>>>>> https://gohugo.io/tools/search/ , have those been tried?
>>>>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
>>>>>> wrote:
>>>>>>> Hi Daniel,
>>>>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>>>>> starting with something for the website, we are missing a search engine
>>>>>>> there. There were a couple of attempts in the past but none of them worked
>>>>>>> fully as expected. Have a look at the PRs here:
>>>>>>> https://github.com/OSGeo/grass-website/pulls
>>>>>>> Best,
>>>>>>> Vero
>>>>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<
>>>>>>> wenzeslaus at gmail.com>) escribió:
>>>>>>>> Hi Daniel,
>>>>>>>> Welcome. That sounds great. For Python, check this presentation I'm
>>>>>>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>>>>> coding standards and the load of tools which can be applied:
>>>>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>>>>> JavaScript at this point means starting with your own idea which
>>>>>>>> may or may not be what you are looking for. Website is certainly one option.
>>>>>>>> I would really like to see changes in the documentation (aka HTML
>>>>>>>> manual pages):
>>>>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>>>>> ...but that's certainly "bring your own idea." It likely involves
>>>>>>>> some HTML and CSS design, but perhaps there is something more functional
>>>>>>>> that can be done. An alternative to this is migrating to Sphinx first, but
>>>>>>>> that's just a thought from the past.
>>>>>>>> Now when I think about it, the full JavaScript checks in
>>>>>>>> Super-Liner are not enabled, so that's perhaps a small JavaScript task to
>>>>>>>> tackle before starting a bigger project (that's up to you!).
>>>>>>>> Let me know if there is any other info which would be helpful.
>>>>>>>> Best,
>>>>>>>> Vaclav
>>>>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>>>>> JS and front end stuff, but also with Python.
>>>>>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>>>>>> something on the website side?)
>>>>>>>>> Cheers,
>>>>>>>>>   Daniel
>>>>>>>>> _______________________________________________
>>>>>>>>> grass-dev mailing list
>>>>>>>>> grass-dev at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/a1b20eb7/attachment-0001.htm>
