[GRASS-dev] mkhtml fails on Windows with UnicodeDecodeError
Martin Landa landa.martin at gmail.com
Fri Aug 26 09:14:34 PDT 2022
st 24. 8. 2022 v 12:03 odesílatel Vaclav Petras <wenzeslaus at gmail.com>
napsal
> Back to the original problem, how can we solve the problem with
>> compilation on Windows 2016 without changing the code base of grass78
>> significantly? BTW, I was able to compile grass78 on the same machine a few
>> weeks ago and I don't see any related changes in v.random.html... (?)
> The PR looks okay on the surface. Maybe you can just remove the
> problematic character in 7.8.
Source of the problem is a git log message [1], not the manual page itself.
I modified PR [2]:
* HTML file is decode using ISO-8859-1
* git log message is decoded using UTF-8
Martin
[1]
https://github.com/OSGeo/grass/commit/3b6d257bdfc18a58dd42c5ab06c69ada99c56a24
[2] https://github.com/OSGeo/grass/pull/2533/files
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220826/0819136b/attachment.htm>
