[GRASS-dev] Question on the CDHC library
Nicklas Larsson n_larsson at yahoo.com
Wed Dec 7 00:24:39 PST 2022
The deafening response on this issue :-) suggests to me it is safe to remove the unused function 'Cdhc_enormp()’ from the CDHC library.
If there are no objections I will shortly merge the PR:
https://github.com/OSGeo/grass/pull/2640
> On 10 Nov 2022, at 15:39, Nicklas Larsson <n_larsson at yahoo.com> wrote:
> Hi all!
> Is there someone tuning in to this list that has knowledge on the content and history of the GRASS library CDHC?
> In a recent PR dealing with compiler warnings a strange line of code in Cdhc_enormp() was discussed [1].
> It turned out we could not find any documentation on what this function is supposed to do and --more importantly-- that it was not even used. I therefore put up a PR suggesting to remove that function [2], but I wanted to give it a last chance with this post…
> I also posted a PR [3] for adding the statlib cdh Fortran source code by Paul Johnson (which the cdhc library code was based upon) to the library documentation.
> Best,
> Nicklas
> [1] https://github.com/OSGeo/grass/pull/2164#discussion_r1014211809 <https://github.com/OSGeo/grass/pull/2164#discussion_r1014211809>
> [2] https://github.com/OSGeo/grass/pull/2640 <https://github.com/OSGeo/grass/pull/2640>
> [3] https://github.com/OSGeo/grass/pull/2642 <https://github.com/OSGeo/grass/pull/2642>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221207/db80f476/attachment.htm>
