[GRASS-dev] Filter STDS by spatial index
Paulo van Breugel p.vanbreugel at gmail.com
Tue Dec 20 00:53:07 PST 2022
On December 14, 2022 15:24:28 Stefan Blumentrath
<Stefan.Blumentrath at gmx.de> wrote:
> Hei,
> I do have a use case where I would like to filter maps in a STRDS by
> spatial extent before e.g. t.rast.univar processes all registered maps.
> In particular, I want to process only maps from a STRDS that intersect with
> the current computational region.
> The reason is that the maps registered in the STRDS are collections of
> single scenes of satellite images or collections of smaller mosaics that
> cover only parts of the total extent of the STRDS.
> Currently, that does not seem to be supported by TGIS, and I see two
> options to address that:
>    a) patch the scenes together with a given granularity (e.g. daily mosaics),
>    leave GRASS GIS functions untouched and hope that there is some coverage
>    for reasonable region settings. or:
>    b) add a spatial filter to the "get_registered_maps"[1] function in
>    abstract_space_time_dataset.py, and then subsequently flags to relevant
>    modules that make use modified function...
> For b) I would think that the most efficient way to handle it would be to
> add a where clause like it was done for the semantic labels? In that case,
> it may make sense to add an index for north, south, east, and west too, no?
> Maybe also top and bottom...
> My main question, however is if my case is just a corner case, or does some
> sort of spatial filteing possibility make sense in general / more broadly...
It seems a bit of a corner case, but in fact something I could use, of I
understand it right.
> Any feedback is much appreciated, esp. before I evtl. start working on b).
> Kind regards,
> Stefan
> 1)
> https://github.com/OSGeo/grass/blob/main/python/grass/temporal/abstract_space_time_dataset.py#L1604
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221220/e20d4629/attachment.htm>
