[GRASS-dev] new addon
Francesco Geri
francescogeri at tim.it
Tue Feb 1 06:01:02 PST 2022
Thank you very much.
Cloning my fork everything gone ok.
I created a new branch called "r.forcircular", add the new folder and
then commit/push. Then I did the pull request at the website.
I hope I did everything right this time.
Thanks again.
Il 01/02/22 12:41, Ondřej Pešek ha scritto:
> út 1. 2. 2022 v 12:40 odesílatel Francesco Geri <francescogeri at tim.it
> <mailto:francescogeri at tim.it>> napsal:
> /git clone git at github.com:fra-lab/grass.git
> <mailto:git at github.com:fra-lab/grass.git>/
> ///Clone in 'grass' in corso...//
> //The authenticity of host 'github.com <http://github.com>
> (140.82.121.3)' can't be established.//
> //ECDSA key fingerprint is
> SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.//
> //Are you sure you want to continue connecting
> (yes/no/[fingerprint])? yes//
> //Warning: Permanently added 'github.com
> <http://github.com>,140.82.121.3' (ECDSA) to the list of known
> hosts.//
> //git at github.com <mailto:git at github.com>: Permission denied
> (publickey).//
> //fatal: Impossibile leggere dal repository remoto.//
> //Assicurati di disporre dei privilegi d'accesso corretti//
> //e che il repository esista./
> In english:
> /fatal: Unable to read from remote repository.
> Make sure you have the correct access privileges
> and that the repository exists.
> Did you fork the repository before trying to clone it? I cannot see
> your fork in the list of forks and also not on your profile when
> stalking it.
> You can do it interactively at the website by going to [1] or [2]
> (depending on whether you want to fork GRASS itself, or the addons
> repository) and clicking on "Fork" in the upper right corner. If you
> didn't do that, then the repository fra-lab/grass does not exist and
> therefore couldn't be cloned.
> [1] https://github.com/OSGeo/grass <https://github.com/OSGeo/grass>
> [2] https://github.com/OSGeo/grass-addons
> <https://github.com/OSGeo/grass-addons>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220201/b29d4fb7/attachment.html>
