[GRASS-dev] GRASS 8.0 support in GDAL and QGIS
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Feb 25 08:13:41 PST 2022
On 2/24/22 09:33, Sebastiaan Couwenberg wrote:
> # ogrinfo -ro -so /tmp/spearfish60_grass7/PERMANENT/vector/roads/head
> Warning 1: GRASS warning: GISBASE environment variable was not set, using:
> /usr/lib/grass80
> /usr/lib/grass80/driver/db/sqlite: error while loading shared libraries:
> libgrass_dbmidriver.8.0.so: cannot open shared object file: No such file
> or directory
> dbmi: Protocol error
> Warning 1: GRASS warning: Unable to start driver <sqlite>
> ERROR 1: Cannot open database sqlite by driver
> /tmp/spearfish60_grass7/PERMANENT/sqlite/sqlite.db, check if GISBASE
> environment variable is set, the driver is available  and the database
> is accessible.
> INFO: Open of `/tmp/spearfish60_grass7/PERMANENT/vector/roads/head'
>        using driver `OGR_GRASS' successful.
> 1: roads (Line String)
FWIW grass (7.8.7-1) in unstable, grass (7.8.6-1) in testing, and grass
(7.6.0-1) in buster have the same issue.
So the good news it's not a regression in 8.0.x.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
