[GRASS-dev] Question on the CDHC library
Nicklas Larsson n_larsson at yahoo.com
Thu Nov 10 06:39:31 PST 2022
Hi all!
Is there someone tuning in to this list that has knowledge on the content and history of the GRASS library CDHC?
In a recent PR dealing with compiler warnings a strange line of code in Cdhc_enormp() was discussed [1].
It turned out we could not find any documentation on what this function is supposed to do and --more importantly-- that it was not even used. I therefore put up a PR suggesting to remove that function [2], but I wanted to give it a last chance with this post…
I also posted a PR [3] for adding the statlib cdh Fortran source code by Paul Johnson (which the cdhc library code was based upon) to the library documentation.
Best,
Nicklas
[1] https://github.com/OSGeo/grass/pull/2164#discussion_r1014211809 <https://github.com/OSGeo/grass/pull/2164#discussion_r1014211809>
[2] https://github.com/OSGeo/grass/pull/2640 <https://github.com/OSGeo/grass/pull/2640>
[3] https://github.com/OSGeo/grass/pull/2642 <https://github.com/OSGeo/grass/pull/2642>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221110/a79f0bb7/attachment.htm>
