[GRASS-dev] Proposal for using ClangFormat, replacing GNU indent, for C/C++ code formatting
Nicklas Larsson n_larsson at yahoo.com
Thu Jan 26 06:07:04 PST 2023
Even,
Thanks for the pointer to pre-commit!
All,
The complete GRASS source is now formatted with ClangFormat using the settings of the added ‘.clang-format’ file.
I have also added a '.pre-commit-config.yaml’, which facilitates the convenient use of ‘pre-commit’ [1].
The pre-commit hooks now supported are:
-  clang-format (for C, C++, JavaScript, JSON, Objective-C)
-  trailing-whitespace
-  end-of-file-fixer
-  markdownlint
-  black
-  flake8
For all developers, I **strongly recommend** installing and using pre-commit. It makes life so much easier and unloads considerable amount of unnecessary work on the CI runners (oh, Black failed, now ClangFormat too, push again…).
The submitting guides on the wiki has been converted to markdown and are awaiting the final destination in source repo [2]. After merge they need to be updated accordingly to latest developments.
The question now is, are there any objections to do the same treatment to grass-addons)?
There are three PRs in-store [3-5] to make that happen.
Cheers,
Nicklas
[1] https://pre-commit.com
[2] https://github.com/OSGeo/grass/pull/2765
[3] https://github.com/OSGeo/grass-addons/pull/852
[4] https://github.com/OSGeo/grass-addons/pull/853
[5] https://github.com/OSGeo/grass-addons/pull/854
> On 2 Jan 2023, at 19:44, Even Rouault <even.rouault at spatialys.com> wrote:
> I'd suggest you use pre-commit so that clang-format is automatically run on git commit operations like we have done with GDAL. Then it is a no-brainer to do changes.
> You need to add a .pre-commit-config.yaml at the root of the repository (only the part referencing clang-format athttps://github.com/OSGeo/gdal/blob/master/.pre-commit-config.yaml#L30 <https://github.com/OSGeo/gdal/blob/master/.pre-commit-config.yaml#L30> is relevant for you):
> https://github.com/OSGeo/gdal/blob/master/.pre-commit-config.yaml <https://github.com/OSGeo/gdal/blob/master/.pre-commit-config.yaml>
> Once that file is in place:
> -  "pip install pre-commit" : just once
> - "pre-commit install": just once per repository
> Cf https://gdal.org/development/dev_practices.html#commit-hooks <https://gdal.org/development/dev_practices.html#commit-hooks>
> Even
> Le 02/01/2023 à 19:20, Nicklas Larsson via grass-dev a écrit :
>> Markus,
>>> On 2 Jan 2023, at 13:48, Markus Neteler <neteler at osgeo.org <mailto:neteler at osgeo.org>> wrote:
>>> Hi Nicklas,
>>> On Wed, Dec 21, 2022 at 9:25 PM Nicklas Larsson via grass-dev
>>> <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>> wrote:
>>>> I understand there is agreement on using the .clang-format formatting rules suggested with [1], which I just merged.
>>>> I have formatted the whole source base with clang-format v.15.0.6, in 7 different PRs [2-8]. I will start merging them tomorrow if there are no objections.
>>>> I have also filed a PR [9] which adds a CI check for clang-format errors.
>>> Thanks for your efforts on the code reformatting!
>>>> Installing clang-format is perhaps most easily done with:
>>>> python -m pip install 'clang-format==15.0.6'
>>>> Formatting may be done with something like (following works on Mac):
>>>> find -E . -regex '.*\.(cpp|hpp|c|h)' -exec clang-format -i {} \+
>>> ... it fails on Linux, though
>>> find: unknown predicate `-E')
>> I was pretty sure this would deviate from Mac/BSD on Linux systems:
>> Try something like (untested):
>> find . -regex '.*\.(cpp|hpp|c|h)' -exec clang-format -i {} \;
>> or manually with:
>> clang-format -I <file>
>>>> Contribution rules must be updated, I will start putting up a draft ASAP.
>>> I am trying to fix the conflicts in
>>> https://github.com/OSGeo/grass/pull/2684 <https://github.com/OSGeo/grass/pull/2684>
>>> Conflicting files:
>>> include/grass/iostream/mm.h
>>> lib/db/dbmi_base/dbmscap.c
>>> lib/external/ccmath/ccmath.h
>>> lib/gis/spawn.c
>>> lib/gis/user_config.c
>>> lib/iostream/rtimer.cpp
>>> lib/pngdriver/graph_set.c
>>> lib/rst/interp_float/point2d.c
>>> raster/r.terraflow/filldepr.cpp
>>> raster/r.terraflow/flow.cpp
>>> raster/r.terraflow/main.cpp
>>> raster/r.viewshed/statusstructure.cpp
>>> The reason will be the missing clang-format update which I don't know
>>> how to apply on Linux.
>> Not quite sure what you mean. Did you try:
>> python -m pip install 'clang-format==15.0.6’
>> But I suspect any version 15 will do, perhaps even v. 14.
>> A tip to use the .clang-format file from main for branches without it:
>> 1. git checkout main
>> 2. cp .clang-forrmat ../.clang-format
>> 3. check out branch
>> 4. clang-format searches upwards in dir hierarchy  for next ‘.clang-format’ file
>> 5. run clang-format from grass source dir
>> grass-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-dev <https://lists.osgeo.org/mailman/listinfo/grass-dev>
> http://www.spatialys.com <http://www.spatialys.com/>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230126/2e1b74a5/attachment.htm>
