[GRASS-dev] shift raster when projecting
Markus Neteler neteler at osgeo.org
Thu Jun 22 02:55:07 PDT 2023
On Fri, Jun 16, 2023 at 7:39 AM Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Dear all,
> I am trying to project a DSM raster layer from Belgium (https://overheid.vlaanderen.be/en/producten-diensten/digital-elevation-model; EPSG 31370 to EPSG 28992 (Amersfoort / RD New).
> The result is a DEM raster layer with the features shifted roughly 100 m as compared to the same features in the AHN (Dutch DEM, https://www.ahn.nl/ahn-4). See screenshot and code below.
> Reprojecting the same in QGIS using the warp function (gdalwarp) results in the Belgium DSM layer to be fairly closely aligned to the Dutch one.
> I tried to set the bounds before, align to the target raster, and other suggestions in the help file of r.proj, to no avail. Any idea what I might be doing wrong?
Just guessing, maybe some geodetic datum file missing?
Maybe try this?
# https://proj.org/usage/environmentvars.html#envvar-PROJ_NETWORK
export PROJ_NETWORK=ON
Markus
