[GRASS-dev] [release planning] GRASS GIS 8.3.0
Martin Landa landa.martin at gmail.com
Fri Jun 23 01:36:09 PDT 2023
pá 23. 6. 2023 v 10:31 odesílatel Markus Neteler <neteler at osgeo.org> napsal:
> note: If you believe this is a mistake, please contact your Python
> installation or OS distribution provider. You can override this, at
> the risk of breaking your Python installation or OS, by passing
> --break-system-packages.
> hint: See PEP 668 for the detailed specification.
> Error: building at STEP "RUN pip3 install grass-session": while
> running runtime: exit status 1
I think that --break-system-packages could be used in this case. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230623/387ad859/attachment.htm>
