[GRASS-dev] winGRASS compilation: configure: error: *** Unable to locate bzlib library.
Helmut Kudrnovsky hellik at web.de
Mon Mar 6 23:20:07 PST 2023
>>I would probably refer to:
>>https://github.com/OSGeo/grass/blob/main/.github/workflows/osgeo4w.yml
>then I get the same error:
>checking for location of zlib includes...
>checking zlib.h usability... yes
>checking zlib.h presence... yes
>checking for zlib.h... yes
>checking for location of zlib library...
>checking for deflate in -lz... yes
>checking whether to use bzlib... "yes"
>checking for location of bzlib includes...
>checking bzlib.h usability... yes
>checking bzlib.h presence... yes
>checking for bzlib.h... yes
>checking for location of bzlib library...
>checking for BZ2_bzBuffToBuffCompress in -lbz2... no
>=> configure: error: *** Unable to locate bzlib library. <=
looking into config.log:
configure:7706: checking whether to use bzlib
configure:7708: result: "yes"
configure:7723: checking for location of bzlib includes
configure:7730: result:
configure:7749: checking bzlib.h usability
configure:7749: x86_64-w64-mingw32-gcc -c -g -O2     -I/c/OSGeo4W/include conftest.c >&5
configure:7749: $? = 0
configure:7749: result: yes
configure:7749: checking bzlib.h presence
configure:7749: x86_64-w64-mingw32-gcc -E    -I/c/OSGeo4W/include conftest.c
configure:7749: checking for bzlib.h
configure:7769: checking for location of bzlib library
configure:7776: result:
configure:7795: checking for BZ2_bzBuffToBuffCompress in -lbz2
configure:7818: x86_64-w64-mingw32-gcc -o conftest.exe -g -O2    -I/c/OSGeo4W/include   -Wl,--export-dynamic,--enable-runtime-pseudo-reloc  -L/c/OSGeo4W/lib -L/c/OSGeo4W/bin conftest.c -lbz2   >&5
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: warning: --export-dynamic is not supported for PE+ targets, did you mean --export-all-symbols?
Warning: corrupt .drectve at end of def file
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../lib/libmingw32.a(lib64_libmingw32_a-merr.o): in function `_matherr':
C:/M/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/merr.c:46: undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x6a0): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x6c2): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x759): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x2350): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x2372): more undefined references to `fprintf' follow
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x3747): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.text$mn+0x3a74): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(bzlib.obj):(.xdata+0x458): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(decompress.obj):(.text$mn+0x22): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(decompress.obj):(.text$mn+0x799): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(decompress.obj):(.text$mn+0x1ed2): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(decompress.obj):(.text$mn+0x27fa): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(decompress.obj):(.xdata+0x20): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x88): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x880): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0xab2): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0xcc0): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0xd12): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0xd6b): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0xf46): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x254a): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x256f): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x2591): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x29d4): more undefined references to `fprintf' follow
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x465d): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.text$mn+0x4683): undefined reference to `__report_rangecheckfailure'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.xdata+0xa0): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(compress.obj):(.xdata+0xc8): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(huffman.obj):(.text$mn+0x6e): undefined reference to `__chkstk'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(huffman.obj):(.text$mn+0x78): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(huffman.obj):(.text$mn+0x5b3): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(huffman.obj):(.xdata+0x24): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0xe9): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x11c): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x29a): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x5fb): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x637): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x676): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0xbd7): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0xdfe): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0xe3f): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0xeaf): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x15ca): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x19c5): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x1a05): undefined reference to `__security_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x1a66): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x1dad): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x2108): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x2477): undefined reference to `fprintf'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x248f): undefined reference to `__security_check_cookie'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.text$mn+0x24a6): undefined reference to `__report_rangecheckfailure'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.xdata+0xd4): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.xdata+0xf4): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.xdata+0x1c8): undefined reference to `__GSHandlerCheck'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/12.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/OSGeo4W/lib/libbz2.lib(blocksort.obj):(.xdata+0x1e8): undefined reference to `__GSHandlerCheck'
collect2.exe: error: ld returned 1 exit status
anyone any idea?
best
helli
