[GRASS-dev] cost surface with negative friction odd behavior
Michael Barton Michael.Barton at asu.edu
Wed Nov 29 12:55:45 PST 2023
Thanks Anna and Doug,
I did not expect it to work (thought it would be useful if it did). Rather I was surprised by the fact that r.walk DID run and that it gave very odd results.
Adding to the docs is a good idea. Even better would also to have a friction map with a negative value (min<0) raise an error in r.walk, saying that all values in a friction map must be ≥ 0
Michael
_____________________________
C. Michael Barton
Associate Director, School of Complex Adaptive Systems (https://scas.asu.edu<https://scas.asu.edu/>)
Professor, School of Human Evolution & Social Change (https://shesc.asu.edu)
Director, Center for Social Dynamics & Complexity (https://complexity.asu.edu)
Arizona State University
Tempe, AZ 85287-2701
USA
Executive Director, Open Modeling Foundation (https://openmodelingfoundation.github.io<https://openmodelingfoundation.github.io/>)
Director, Network for Computational Modeling in Social & Ecological Sciences (https://comses.net)
personal website: http://www.public.asu.edu/~cmbarton
On Nov 29, 2023, at 1:00 PM, grass-user-request at lists.osgeo.org wrote:
Date: Wed, 29 Nov 2023 10:17:19 -0500
From: Anna Petr??ov? <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
To: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
Cc: GRASS developers <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>, GRASS user list
<grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: Re: [GRASS-user] cost surface with negative friction odd
behavior
Message-ID:
<CAE0EDEoFhX75U2r6qC8eK5p8czg2Cd1iWR8J3vX8QiWWE8zNUw at mail.gmail.com<mailto:CAE0EDEoFhX75U2r6qC8eK5p8czg2Cd1iWR8J3vX8QiWWE8zNUw at mail.gmail.com>>
Content-Type: text/plain; charset="utf-8"
I think r.walk was not written for negative friction and while I imagine
some small (in absolute sense) negative values may work, your negative
values are pretty extreme, meaning the resulting travel time through a cell
would be negative. That can cause all kinds of issues in the algorithm. So
I would say friction should not be negative. I am not sure I would check
that in the code, because you would need to check that for each cell and I
think it's unnecessary overhead. Maybe just adding a note to documentation
may be enough. I haven't looked into the code itself, so this is just my
guess.
Anna
On Tue, Nov 28, 2023 at 5:48?PM Michael Barton via grass-user <
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>> wrote:
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20231129/a35a5202/attachment-0001.htm>
