[GRASS-dev] A load of updates in OSGeo4W
Nicklas Larsson n_larsson at yahoo.com
Mon Apr 15 12:14:31 PDT 2024
Jürgen,
Thank you very much for this gigantic task of putting all these pieces together,
I’m sure the Windows users will be delighted!
Best,
Nicklas
> On 15 Apr 2024, at 01:02, Jürgen E. Fischer via grass-dev <grass-dev at lists.osgeo.org> wrote:
> Hi there,
> I just uploaded an update to OSGeo4W.   It is basically a rebuild of everything
> with a newer compiler (Visual C++ 2022) and updates of almost all versions.
> The update should work cleanly and cause no visual changes.
> The main change is the move from Python 3.9.18 to 3.12.3.  But there's also an
> update to Qt 5.15.13, OpenSSL 3.   Qt6 was also added enabling an experimental
> build of QGIS master with Qt6. Based on that there is also an experimental
> version of QField.
> GDAL and PROJ also were updated to the latest version.
> The legacy GRASS 7 was removed because it doesn't support Python 3.12.  GRASS 8
> was already available and QGIS switch to it long before this update.
> Please test and report.
> Jürgen
> More details in the commit message:
> A load of updates (fixes #788, #810, #816, #819, #820, #823, closes jef-n/OSGeo4W#21, refs qgis/QGIS#54491, qgis/QGIS#56499)
> Highlights:
>  Switched to Visual Studio 2022
>  Qt6 6.6.3, PyQt6 6.6.1
>  Qt5 5.15.13, PyQt5 5.15.10
>  Python 3.12.3
>  OpenSSL 3.0.13
>  PROJ 9.4.0
>  GDAL 3.8.5
>  qgis-qt6-dev based on Qt6 next to qgis-dev based on Qt5
>  experimental QField based on Qt6 / qgis-qt6-dev
> Details:
>  Removed:
>    libjpeg (already replaced with libjpeg-turbo earlier)
>    python3-clcache (replaced by ccache)
>    python3-pyuv (dependency of python3-clcache)
>  Updated:
>    apache 2.4.52 -> 2.4.58
>    arrow-cpp 7.0.0 -> 15.0.2
>    boost 1.74.0 -> 1.84.0
>    brotli 1.0.9 -> 1.1.0
>    curl 8.4.0 -> 8.6.0
>    draco 1.5.6 -> 1.5.7
>    exiv2 0.27.3 -> 0.28.2
>    expat 2.2.10 -> 2.6.2
>    ffmpeg 5.1 -> 6.1.1
>    freetype 2.10.2 -> 2.13.2
>    gdal 3.8.4 -> 3.8.5
>    gpsbabel 1.8.0 -> 1.9.0
>    grass 7.8.8 -> 8.3.2
>    grass8 8.3.2 -> 99 (transitional; depends on grass)
>    gsl 2.6 -> 2.7.1+
>    hdf4 4.2.16 -> 4.3.0
>    hdf5 1.14.0 -> 1.14.3
>    kealib 1.4.14 -> 1.5.3
>    lerc 3.0 -> 4.0.0
>    libharu 2.3.0 -> 2.4.4
>    libiconv 1.16 -> 1.17
>    libjpeg-turbo 2.0.7-esr -> 3.0.2
>    libjxl 0.8.1 -> 0.10.2
>    libmysql 8.0.21 -> 8.2.0
>    libosmium-devel 2.18.0 -> 2.20.0
>    libpng 1.6.37 -> 1.6.43
>    libtiff 4.5.1 -> 4.6.0
>    libxml2 2.9.10 -> 2.12.5
>    libxslt 1.1.34 -> 1.1.39
>    libzip 1.7.3 -> 1.10.1
>    lua 5.4.4 -> 5.4.6
>    lz4 1.9.3 -> 1.9.4
>    minizip-ng-devel 3.0.2 -> 4.0.4
>    node 16.14.0 -> 20.11.1
>    oci 19.11 -> 21.13
>    ogdi 4.1.0 -> 4.1.1
>    opencl 2.0.10 -> 2023.12.14
>    openfyba-devel 20150103 -> 20240408
>    openjpeg 2.4.0 -> 2.5.2
>    openssl 1.1.1w -> 3.0.13
>    osm2pgsql 1.8.1 -> 1.11.0
>    osmium 1.15.0 -> 1.16.0
>    pdal 2.6.0 -> 2.6.3
>    poppler 23.07.0 -> 24.04.0
>    proj 9.3.1 -> 9.4.0
>    proj-data 1.16 -> 1.17
>    python3 3.9.18 -> 3.12.3
>    protobuf-devel 3.13.0 -> 25.3
>    qca 2.3.1 -> 2.3.8
>    qscintilla 2.13.4 -> 2.14.1
>    qt5 5.15.3 -> 5.15.13
>    qtkeychain 0.13.2 -> 0.14.2
>    qwc2 20220311-671a6e7 -> 20240408-3d95409
>    qwt 6.1.6 -> 6.2.0
>    saga 7.8.2 -> 9.3.1
>    saga9 9.2.0 -> 99 (transitional; depends on saga)
>    snappy-devel 1.1.9 -> 1.1.10
>    spdlog-devel 1.10.0 -> 1.13.0
>    sqlite3 3.41.1 -> 3.45.1
>    swig 4.0.2 -> 4.2.1
>    thrift 0.16.0 -> 0.20.0
>    transifex-cli 1.6.5 -> 1.6.10
>    utf8proc 2.7.0 -> 2.9.0
>    wxwidgets 3.2.1 -> 3.2.4
>    xerces-c 3.2.3 -> 3.2.5
>    xz 5.2.5 -> 5.4.5
>    yarnpkg 1.22.17 -> 1.22.21
>    zlib 1.2.12 -> 1.3.1
>    zstd 1.4.5 -> 1.5.5
>  Updated Python extensions:
>    python3-access 1.1.1 -> 1.1.9
>    python3-affine 2.3.0 -> 2.4.0
>    python3-alabaster 0.7.12 -> 0.7.16
>    python3-argon2-cffi 20.1.0 -> 23.1.0
>    python3-atomicwrites 1.4.0 -> 1.4.1
>    python3-attrdict 2.0.1 -> python3-attrdict3 2.0.2
>    python3-attrs 20.2.0 -> 23.2.0
>    python3-autopep8 2.0.1 -> 2.1.0
>    python3-babel 2.8.0 -> 2.14.0
>    python3-backports.entry-points-selectable 1.1.0 -> 1.3.0
>    python3-beautifulsoup4 4.9.3 -> 4.12.3
>    python3-bleach 3.2.1 -> 6.1.0
>    python3-certifi 2020.6.20 -> 2024.2.2
>    python3-cffi 1.14.3 -> 1.16.0
>    python3-cftime 1.2.1 -> 1.6.3
>    python3-chardet 3.0.4 -> 5.2.0
>    python3-click 7.1.2 -> 8.1.7
>    python3-cligj 0.7.0 -> 0.7.2
>    python3-colorama 0.4.4 -> 0.4.6
>    python3-coverage 5.3 -> 7.4.4
>    python3-cycler 0.10.0 -> 0.12.1
>    python3-decorator 4.4.2 -> 5.1.1
>    python3-defusedxml 0.6.0 -> 0.7.1
>    python3-distlib 0.3.2 -> 0.3.8
>    python3-docutils 0.16 -> 0.20.1
>    python3-entrypoints 0.3 -> 0.4
>    python3-esda 2.3.1 -> 2.5.1
>    python3-exifread 2.3.2 -> 3.0.0
>    python3-filelock 3.0.12 -> 3.13.3
>    python3-fiona 1.9.5 -> 1.9.6
>    python3-fonttools 4.28.5 -> 4.51.0
>    python3-future 0.18.2 -> 1.0.0
>    python3-gdal 3.8.4 -> 3.8.5
>    python3-geoalchemy2 0.12.5 -> 0.14.7
>    python3-geographiclib 1.50 -> 2.0
>    python3-geopandas 0.14.1 -> 0.14.3
>    python3-giddy 2.3.3 -> 2.3.5
>    python3-greenlet 1.1.1 -> 3.0.3
>    python3-h5py 3.8.0 -> 3.10.0
>    python3-httplib2 0.18.1 -> 0.22.0
>    python3-idna 2.10 -> 3.6
>    python3-imagesize 1.2.0 -> 1.4.1
>    python3-importlib-metadata 2.0.0 -> 7.1.0
>    python3-inequality 1.0.0 -> 1.0.1
>    python3-iniconfig 1.1.1 -> 2.0.0
>    python3-ipykernel 5.3.4 -> 6.29.4
>    python3-ipython 7.18.1 -> 8.23.0
>    python3-ipywidgets 7.5.1 -> 8.1.2
>    python3-isort 5.12.0 -> 5.13.2
>    python3-jedi 0.17.2 -> 0.19.1
>    python3-jinja2 3.1.2 -> 3.1.3
>    python3-joblib 0.17.0 -> 1.3.2
>    python3-jsonschema 3.2.0 -> 4.21.1
>    python3-jupyter-client 6.1.7 -> 8.6.1
>    python3-jupyter-console 6.2.0 -> 6.6.3
>    python3-jupyter-core 4.6.3 -> 5.7.2
>    python3-jupyterlab-pygments 0.1.2 -> 0.3.0
>    python3-kiwisolver 1.2.0 -> 1.4.5
>    python3-libpysal 4.3.0 -> 4.10
>    python3-llvmlite 0.34.0 -> 0.42.0
>    python3-lxml 4.6.2 -> 5.2.1
>    python3-mapclassify 2.3.0 -> 2.6.1
>    python3-markupsafe 1.1.1 -> 2.1.5
>    python3-matplotlib 3.5.1 -> 3.8.4
>    python3-mgwr 2.1.2 -> 2.2.1
>    python3-mistune 0.8.4 -> 3.0.2
>    python3-mock 4.0.2 -> 5.1.0
>    python3-mod-wsgi 4.9.0 -> 5.0.0
>    python3-mpmath 1.1.0 -> 1.3.0
>    python3-munch 2.5.0 -> 4.0.0
>    python3-nbclient 0.5.1 -> 0.10.0
>    python3-nbconvert 6.0.7 -> 7.16.3
>    python3-nbformat 5.0.8 -> 5.10.4
>    python3-nest-asyncio 1.4.2 -> 1.6.0
>    python3-netcdf4 1.6.3 -> 1.6.5
>    python3-networkx 2.5 -> 3.3
>    python3-nltk 3.5 -> 3.8.1
>    python3-nose2 0.9.2 -> 0.14.1
>    python3-notebook 6.1.4 -> 7.1.2
>    python3-numba 0.51.2 -> 0.59.0
>    python3-numpy 1.24.1 -> 1.26.4
>    python3-openpyxl 3.0.9 -> 3.1.2
>    python3-osmium 3.4.1 -> 3.7.0
>    python3-owslib 0.29.2 -> 0.30.0
>    python3-packaging 20.4 -> 24.0
>    python3-pandas 2.0.2 -> 2.2.1
>    python3-pandocfilters 1.4.3 -> 1.5.1
>    python3-parso 0.8.0 -> 0.8.4
>    python3-patsy 0.5.1 -> 0.5.6
>    python3-pbr 5.5.1 -> 6.0.0
>    python3-pdal-plugins 1.2.1 -> 1.3.0
>    python3-pillow 10.0.1 -> 10.3.0
>    python3-pirogue 1.2.5 -> 1.4.2
>    python3-platformdirs 2.0.2 -> 4.2.0
>    python3-plotly 4.12.0 -> 5.20.0
>    python3-pluggy 0.13.1 -> 1.4.0
>    python3-pointpats 2.2.0 -> 2.4.0
>    python3-prometheus-client 0.8.0 -> 0.20.0
>    python3-prompt-toolkit 3.0.8 -> 3.0.43
>    python3-psycopg 3.1.9 -> 3.1.18
>    python3-psycopg2-binary 2.9.3 -> 2.9.9
>    python3-pum 0.9.12 -> 0.10.0
>    python3-py 1.9.0 -> 1.11.0
>    python3-pybind11 2.6.2 -> 2.12.0
>    python3-pycparser 2.20 -> 2.22
>    python3-pygments 2.7.2 -> 2.17.2
>    python3-pymemcache 3.4.0 -> 4.0.0
>    python3-pyodbc 4.0.30 -> 5.1.0
>    python3-pyopengl 3.1.5 -> 3.1.7
>    python3-pyparsing 2.4.7 -> 3.1.2
>    python3-pyqt-builder 1.10.3 -> 1.16.0
>    python3-pyqt5 5.15.4 -> 5.15.10
>    python3-pyqt5-sip 12.8.1 -> 12.13.0
>    python3-pyqtwebengine 5.15.5 -> 5.15.6
>    python3-pyrsistent 0.17.3 -> 0.20.0
>    python3-pysal 2.3.0 -> 24.1
>    python3-pytest 6.1.2 -> 8.1.1
>    python3-pytest-cov 2.10.1 -> 5.0.0
>    python3-python-dateutil 2.8.1 -> 2.9.0.post0
>    python3-pythonqwt 0.8.3 -> 0.12.1
>    python3-pytz 2023.3 -> 2024.1
>    python3-pywinpty 0.5.7 -> 2.0.13
>    python3-pyyaml 5.3.1 -> 6.0.1
>    python3-pyzmq 19.0.2 -> 25.1.2
>    python3-qscintilla 2.13.4 -> 2.14.1
>    python3-qtconsole 4.7.7 -> 5.5.1
>    python3-qtpy 1.9.0 -> 2.4.1
>    python3-quantecon 0.4.8 -> 0.7.2
>    python3-rasterstats 0.15.0 -> 0.19.0
>    python3-regex 2020.10.28 -> 2023.12.25
>    python3-reportlab 4.0.4 -> 4.1.0
>    python3-requests 2.24.0 -> 2.31.0
>    python3-retrying 1.3.3 -> 1.3.4
>    python3-rtree 0.9.4 -> 1.2.0
>    python3-scikit-learn 0.23.2 -> 1.4.1.post1
>    python3-scipy 1.10.1 -> 1.13.0
>    python3-seaborn 0.11.0 -> 0.13.2
>    python3-segregation 1.4.0 -> 2.5
>    python3-send2trash 1.5.0 -> 1.8.3
>    python3-setuptools 67.6.0 -> 69.2.0
>    python3-shapely 2.0.2 -> 2.0.3
>    python3-simplejson 3.17.2 -> 3.19.2
>    python3-sip 6.1.1 -> 6.8.3
>    python3-six 1.15.0 -> 1.16.0
>    python3-snowballstemmer 2.0.0 -> 2.2.0
>    python3-soupsieve 2.0.1 -> 2.5
>    python3-spaghetti 1.5.3 -> 1.7.5.post1
>    python3-spglm 1.0.8 -> 1.1.0
>    python3-sphinx 3.3.0 -> 7.2.6
>    python3-splot 1.1.3 -> 1.1.5.post1
>    python3-spreg 1.1.2.post1 -> 1.4.2
>    python3-sqlalchemy 1.4.42 -> 2.0.29
>    python3-statsmodels 0.14.0 -> 0.14.1
>    python3-sympy 1.6.2 -> 1.12
>    python3-terminado 0.9.1 -> 0.18.1
>    python3-testpath 0.4.4 -> 0.6.0
>    python3-threadpoolctl 2.1.0 -> 3.4.0
>    python3-tobler 0.4.0 -> 0.11.2
>    python3-toml 0.10.1 -> 0.10.2
>    python3-torch 2.2.1 -> 2.2.2
>    python3-tornado 6.0.4 -> 6.4
>    python3-tqdm 4.51.0 -> 4.66.2
>    python3-traitlets 5.0.5 -> 5.14.2
>    python3-typing-extensions 4.5.0 -> 4.11.0
>    python3-tzdata 2023.3 -> 2024.1
>    python3-urllib3 1.25.11 -> 2.2.1
>    python3-virtualenv 20.5.0 -> 20.25.1
>    python3-wcwidth 0.2.5 -> 0.2.13
>    python3-wheel 0.35.1 -> 0.43.0
>    python3-widgetsnbextension 3.5.1 -> 4.0.10
>    python3-xlrd 1.2.0 -> 2.0.1
>    python3-zipp 3.4.0 -> 3.18.1
>  Just rebuilt with VS2022:
>    api-ms-win-core-path-HACK 0.0.1
>    avce00 2.0.0
>    base 1.0.0
>    bzip2-devel 1.0.8
>    cairo 1.17.2
>    entwine 3.0.0
>    fcgi 2.4.2
>    freexl 2.0.0
>    geos 3.12.1
>    gs 10.02.1
>    icu 67.1
>    imposm3 0.11.1
>    laszip 3.4.3
>    libgeotiff 1.7.1
>    libkml-devel 1.3.0
>    liblas 1.8.1
>    libpq 16.2
>    librttopo 1.1.0
>    libspatialindex 1.9.3
>    libspatialite 5.1.0
>    libwebp 1.3.2
>    mod_fcgid 2.3.10
>    netcdf 4.9.2
>    odbc-cpp-wrapper 1.1
>    pcraster 4.4.1
>    protozero-devel 1.7.1
>    qgis 3.36.1
>    qgis-ltr 3.34.5
>    qtwebkit 5.212.0-alpha4
>    qwc-services 1.3.4
>    setup 1.1.2
>    shell 99.0.0
>    szip 2.1.1
>    tiledb 2.8.2
>    wingetopt-devel 1.00
>  Repackaged/rebuilt for Python 3.12
>    python3-async-generator 1.10
>    python3-backcall 0.2.0
>    python3-click-plugins 1.1.1
>    python3-descartes 1.1.0
>    python3-et-xmlfile 1.1.0
>    python3-ipython-genutils 0.2.0
>    python3-jupyter 1.0.0
>    python3-mapproxy 2.0.2
>    python3-mypy-extensions 1.0.0
>    python3-pdal 3.2.3
>    python3-pickleshare 0.7.5
>    python3-pip 24.0
>    python3-ply 3.11
>    python3-pypdf2 3.0.1
>    python3-pypiwin32 223
>    python3-pyproj 3.6.1
>    python3-pypubsub 3.3.0
>    python3-pyserial 3.5
>    python3-pytoml 0.1.21
>    python3-pywin32 306
>    python3-rasterio 1.3.9
>    python3-remotior-sensus 0.3.5
>    python3-snuggs 1.4.7
>    python3-spint 1.0.7
>    python3-spvcm 0.3.0
>    python3-tomli 2.0.1
>    python3-webencodings 0.5.1
>    python3-wxpython 4.2.1
>    python3-xlwt 1.3.0
>  Added:
>    grass7 99 (transitional; depends on grass(8); grass 7 doesn't support python 3.12)
>    podofo 0.10.3
>    qca-qt6 2.3.8
>    qgis-qt6-dev (master based on Qt6)
>    qscintilla-qt6 2.14.1
>    qt6 6.6.3
>    qtkeychain-qt6 0.14.2
>    qwt-qt6 6.2.0
>    uriparser-devel 0.9.7
>    saga7 7.9.1 (old saga, just in case)
>    qfield-dev 3.2.2 (experimental; depends on very heady qgis-qt6-dev; TODO split the latter to minimize qfield dependencies)
>    poly2tri-devel 20240411 (qfield dependency)
>    zxing-cpp-devel 2.2.1 (qfield dependency)
>  Added python extensions:
>    python3-anyio 4.3.0
>    python3-argon2-cffi-bindings 21.2.0
>    python3-asttokens 2.4.1
>    python3-async-lru 2.0.4
>    python3-charset-normalizer 3.3.2
>    python3-comm 0.2.2
>    python3-contourpy 1.2.1
>    python3-debugpy 1.8.1
>    python3-deprecation 2.1.0
>    python3-duckdb 0.10.1
>    python3-executing 2.0.1
>    python3-fastjsonschema 2.19.1
>    python3-fsspec 2024.3.1
>    python3-h11 0.14.0
>    python3-httpcore 1.0.5
>    python3-httpx 0.27.0
>    python3-json5 0.9.24
>    python3-jsonschema-specifications 2023.12.1
>    python3-jupyter-events 0.10.0
>    python3-jupyter-lsp 2.2.5
>    python3-jupyter-server 2.13.0
>    python3-jupyter-server-terminals 0.5.3
>    python3-jupyterlab 4.1.5
>    python3-jupyterlab-server 2.26.0
>    python3-jupyterlab-widgets 3.0.10
>    python3-matplotlib-inline 0.1.6
>    python3-maturin 1.5.1
>    python3-momepy 0.7.0
>    python3-notebook-shim 0.2.4
>    python3-overrides 7.7.0
>    python3-pathspec 0.12.1
>    python3-psutil 5.9.8
>    python3-psycopg2 2.9.9
>    python3-pulp 2.8.0
>    python3-pure-eval 0.2.2
>    python3-pyarrow 15.0.2
>    python3-pycodestyle 2.11.1
>    python3-pyqt6 6.6.1
>    python3-pyqt6-qscintilla 2.14.1
>    python3-pyqt6-sip 13.6.0
>    python3-python-json-logger 2.0.7
>    python3-referencing 0.34.0
>    python3-rfc3339-validator 0.1.4
>    python3-rfc3986-validator 0.1.1
>    python3-rpds-py 0.18.0
>    python3-sniffio 1.3.1
>    python3-sphinxcontrib-applehelp 1.0.8
>    python3-sphinxcontrib-devhelp 1.0.6
>    python3-sphinxcontrib-htmlhelp 2.0.5
>    python3-sphinxcontrib-jsmath 1.0.1
>    python3-sphinxcontrib-qthelp 1.0.7
>    python3-sphinxcontrib-serializinghtml 1.1.10
>    python3-spopt 0.6.0
>    python3-stack-data 0.6.3
>    python3-tenacity 8.2.3
>    python3-tinycss2 1.2.1
>    python3-websocket-client 1.7.0
> Other changes:
> * acceptable licenses updated
> * switch to VS2022
> * add bootstrap.cmd to
> * invoke installation of cygwin base,
> * clone the repo
> * build everything
> * build process installs necessary tools if necessary
> * vs2022
> * debug tools (for dbghelp.dll)
> * cmake
> * ninja
> * ccache (supports msvc now)
> * enables long paths on build (for Qt6 / webengine / chromium)
> * cleanups
> * PACKAGES added to package.sh to list produced packages
> * devenv replaced with msbuild
> * Update of ECWJP2SDKSetup_5.5.0.2268-Update4-Windows.zip not automatically
>  downloadable anymore (place in src/gdal/osgeo4w/gdaldeps and
>  src/gdal-dev/osgeo4w/gdaldeps)
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden            https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
