[GRASS-dev] [GRASS-user] Mini project 2024: Third progress report
Veronica Andreo veroandreo at gmail.com
Mon Apr 22 06:08:18 PDT 2024
Thanks for the report Linda!! And congratulations on the new family
member!! 🥰
Greetings from the GRASS GIS family!
Vero
El lun, 22 abr 2024 a las 3:51, Linda Karlovská via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hello guys,
> I am sending my third progress report from working on the GRASS mini
> project called Easy command history navigation through the History browser
> panel. You can also access the detailed report here: [1].
> 1) What did I complete?
> I completed the PR [2] which enables storing more information about
> executed commands. Newly, commands are stored in JSON format and then
> displayed as the command info in the history pane. I also completed the
> relocation of the Export history button from the Console pane to the
> History pane (PR [3]).
> Besides that, I am working on [4] and [5]. The first PR creates a new
> button for setting the current region to the region used during the command
> execution. This PR is awaiting the final review. The second contribution
> adds time branching to the history browser tree and is currently waiting
> for the review.
> 2) What am I going to achieve for the next two weeks?
> I would like to merge both [4] and [5]. Subsequently, I plan to shift my
> focus toward visualization of command status. I plan to add icons in front
> of command nodes representing possible states (success, failed, in process,
> aborted). Regarding the status, it would also be nice to show the complete
> error text if a command fails. (Now there is “failed” written but no clue
> what happened).
> 3) Is there any blocking issue?
> No, it isn’t. I have just been much more busy the last two months since on
> the 19th of February, my two-member family expanded by one little guy, my
> son Vilem. So any work has gone kind of slowly over the last two months… 🙂
> Have a nice week.
> Linda
> [1]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#Reportforweeks5and6
> [2] https://github.com/OSGeo/grass/pull/3365
> [3] https://github.com/OSGeo/grass/pull/3402
> [4] https://github.com/OSGeo/grass/pull/3421
> [5] https://github.com/OSGeo/grass/pull/3622
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240422/6c00075e/attachment.htm>
