[GRASS-dev] configurare fails: Failed check for math library
Nicklas Larsson n_larsson at yahoo.com
Wed Jan 24 05:00:23 PST 2024
Martin,
Noting that you use a non-default prefix, you may need to add `LDFLAGS="-L/usr/lib”` (and perhaps add ´”-I/usr/include” to CFLAGS and CXXFLAGS).
The same result could perhaps be reached with `--with-includes=/usr/include --with-libs=/usr/lib` added to configure, although that I’m not sure of.
Best,
Nicklas
> On 24 Jan 2024, at 13:34, Martin Landa via grass-dev <grass-dev at lists.osgeo.org> wrote:
> Hi,
> I am unable to compile GRASS on Debian testing. The configure fails with:
> checking for atan... no
> checking for atan in -lm... no
> configure: error: *** Failed check for math library.
> I installed dependencies by
> apt build-dep grass
> and run
>         CFLAGS="-g -Wall -Werror -fno-common -Wextra -Wunused" \
>    CXXFLAGS="-g -Wall"  \
>    ./configure --prefix=/opt/grass \
>             --enable-largefile --enable-shared \
>             --with-blas --with-bzlib --with-cairo --with-cxx --with-freetype \
>             --with-freetype-includes=/usr/include/freetype2 --with-gdal \
>             --with-geos --with-lapack --with-netcdf --with-nls \
>             --with-odbc --with-openmp --with-pdal=no \
>             --with-postgres --with-postgres-includes=/usr/include/postgresql \
>             --with-proj-share=/usr/share/proj --with-readline \
>             --with-sqlite --with-x --with-zstd
> Any idea what could be wrong? Thanks in advance, Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240124/f98526ec/attachment.htm>
