[GRASSGUI] Re: ImportError: No module named aui
Michael Barton michael.barton at asu.edu
Sun Aug 5 15:12:17 EDT 2007
As the errors indicate, you seem to have a mismatch between your wxPython
and Python version. You need to have a version of wxPython 2.8 that uses the
same version of Python you have on your computer--either 2.4 OR 2.5.
Michael
On 7/24/07 3:30 PM, "Tim Michelsen" <timmichelsen at gmx-topmail.de> wrote:
> Hello!
>> I uninstal wx 2.6 and 2.8 and install aganin only 2.8 it help to run
>> wxpython
> I did what you said. The Grass splash scren came up and went away.
> Why do I not see the WxGrass-Windows?
> Here's the error log:
> /usr/lib/python2.4/site-packages/numpy/core/__init__.py:5:
> RuntimeWarning: Python C API version mismatch for module multiarray:
> This Python has API version 1013, module multiarray has version 1012.
>    import multiarray
> /usr/lib/python2.4/site-packages/numpy/core/__init__.py:6:
> RuntimeWarning: Python C API version mismatch for module umath: This
> Python has API version 1013, module umath has version 1012.
>    import umath
> /usr/lib/python2.4/site-packages/numpy/core/__init__.py:9:
> RuntimeWarning: Python C API version mismatch for module _sort: This
> Python has API version 1013, module _sort has version 1012.
>    import _sort
> /usr/lib/python2.4/site-packages/numpy/core/numeric.py:252:
> RuntimeWarning: Python C API version mismatch for module _dotblas: This
> Python has API version 1013, module _dotblas has version 1012.
>    from _dotblas import dot, vdot, inner, alterdot, restoredot
> /usr/lib/python2.4/site-packages/numpy/core/__init__.py:19:
> RuntimeWarning: Python C API version mismatch for module scalarmath:
> This Python has API version 1013, module scalarmath has version 1012.
>    import scalarmath
> /usr/lib/python2.4/site-packages/numpy/lib/function_base.py:25:
> RuntimeWarning: Python C API version mismatch for module _compiled_base:
> This Python has API version 1013, module _compiled_base has version 1012.
>    from _compiled_base import _insert, add_docstring
> /usr/lib/python2.4/site-packages/numpy/linalg/linalg.py:25:
> RuntimeWarning: Python C API version mismatch for module lapack_lite:
> This Python has API version 1013, module lapack_lite has version 1012.
>    from numpy.linalg import lapack_lite
> /usr/lib/python2.4/site-packages/numpy/fft/fftpack.py:28:
> RuntimeWarning: Python C API version mismatch for module fftpack_lite:
> This Python has API version 1013, module fftpack_lite has version 1012.
>    import fftpack_lite as fftpack
> /usr/lib/python2.4/site-packages/numpy/random/__init__.py:3:
> RuntimeWarning: Python C API version mismatch for module mtrand: This
> Python has API version 1013, module mtrand has version 1012.
>    from mtrand import *
> /usr/lib/python2.4/site-packages/_xmlplus/parsers/expat.py:4:
> RuntimeWarning: Python C API version mismatch for module pyexpat: This
> Python has API version 1013, module pyexpat has version 1012.
>    from pyexpat import *
> Error in sys.excepthook:
> Traceback (most recent call last):
>    File "/var/lib/python-support/python2.5/apport_python_hook.py", line
> 30, in apport_excepthook
>      import apport.report, apport.fileutils
>    File "/var/lib/python-support/python2.4/apport/__init__.py", line 1,
> in <module>
>      from apport.report import Report
>    File "/var/lib/python-support/python2.4/apport/report.py", line 20,
> in <module>
>      from problem_report import ProblemReport
> ImportError: Bad magic number in
> /usr/lib/python2.4/site-packages/problem_report.pyc
> Original exception was:
>    File "/usr/lib/grass/etc/wx/wxgui.py", line 918, in <module>
>      app = GMApp(0)
>    File
> "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
> 7757, in __init__
>      self._BootstrapApp()
>    File
> 7354, in _BootstrapApp
>      return _core_.PyApp__BootstrapApp(*args, **kwargs)
>    File "/usr/lib/grass/etc/wx/wxgui.py", line 900, in OnInit
>      mainframe = GMFrame(parent=None, id=wx.ID_ANY, title="")
>    File "/usr/lib/grass/etc/wx/wxgui.py", line 188, in __init__
>      self.NewDisplay()
>    File "/usr/lib/grass/etc/wx/wxgui.py", line 582, in NewDisplay
>      auimgr=self._auimgr)
>    File
> "/usr/local/src/gis/grass/addons/gui/gui_modules/wxgui_utils.py", line
> 135, in __init__
>      Map=self.Map, auimgr=self.auimgr)
>    File "/usr/local/src/gis/grass/addons/gui/gui_modules/mapdisp.py",
> line 1323, in __init__
>      self.AddToolbar(toolb)
> line 1407, in AddToolbar
>      self.maptoolbar = toolbars.MapToolbar(self, self.Map)
>    File "/usr/local/src/gis/grass/addons/gui/gui_modules/toolbars.py",
> line 78, in __init__
>      self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
> line 42, in InitToolbar
>      self.CreateTool(parent, toolbar, *tool)
> line 58, in CreateTool
>      shortHelp, longHelp)
>    File
> "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py",
> line 3715, in AddLabelTool
>      shortHelp, longHelp, clientData)
>    File
> line 3637, in DoAddTool
>      return _controls_.ToolBarBase_DoAddTool(*args, **kwargs)
> ValueError: invalid null reference in method 'ToolBarBase_DoAddTool',
> expected argument 4 of type 'wxBitmap const &'
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
More information about the grass-gui mailing list
