[GRASS-dev] Re: [GRASSGUI] Re: ImportError: No module named aui
Brad Douglas rez at touchofmadness.com
Thu Aug 9 03:01:10 EDT 2007
On Wed, 2007-08-08 at 23:35 -0700, Michael Barton wrote:
> You can use Python 2.4 or 2.5.
> You must have wxPython 2.8 or higher.
> Python and wxPython version numbers are not in sync with each other.
> wxPython version numbers are (I think) in sync with wxWidgets version
> numbers (since wxPython is built on wxWidgets).
> If you have Python 2.4, you must compile wxPython for Python 2.4 (or get a
> binary that is compiled for Python 2.4)
> If you have Python 2.5, you must compile wxPython for Python 2.5 (or get the
> proper binary).
> I recently saw come across the list the comment that wxPython 2.8 will work
> fine with things that need wxPython 2.6 (although the reverse is not true of
> course).
I built RPMs for Fedora Core 6 x86_64 if anyone is interested.  It'll
save a lot of headaches.
73, de Brad KB8UYR/6 <rez touchofmadness com>
More information about the grass-gui mailing list
