[GRASSGUI] cannot change the raster map in layer (wxpython)
Jarek Jasiewicz jarekj at amu.edu.pl
Sun Aug 19 05:22:26 EDT 2007
Michael Barton wrote:
> On 8/11/07 4:51 AM, "Jarek Jasiewicz" <jarekj at amu.edu.pl> wrote:
>> I noticed small issue with wxpython
>> when I try to change the raster map in layer, I cannot. The only way is
>> to remove old laer and add new
>> It is intended?
> Double click layer or get the context menu by right-clicking the layer to
> change it.
Michael, I assume, that if somebody is able to install wxgrass (for
testing purrpose), is also able to find the method you have described.
So I do not desciribed, that both methods. Probably it was my mistake.
So another way:
I have wxgrass installed from 18.08.2007, morning, on ubuntu feisty
I add the layer, ad the raster map to layer and make refresh on map display.
Next step I call the properties window (both method) on layer choose
another map from combo menu, I press aplly and nothing change i.e map
remains the same
I can change the map name manually, e.g I can type the name of the map
in the combo and that way it work. I hope I write it out in propertyly.
I assume that there is three ways:
-for unknow resason it do not works only on my machine
-it do not on ubuntu feisty on the whole
-there is small bug
I rather expected that somebody confirm or not that problem.
So I apologise if my post was misunderstood, thanks for ansfer, and best
wishes in development on wxgrass
Jarek
>> And addational question:
>> how in wxpython choose more then on map in window (for example in
>> g.remove or r.covar)
>> J.
> Need to have a more sophisticated map selector
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
More information about the grass-gui mailing list
