[GRASSGUI] trying to compile wxPython digitizer display_driver
William Kyngesburye woklist at kyngchaos.com
Mon Aug 20 10:25:27 EDT 2007
Strange.  It sees the makefile, or it it would also say it couldn't
find one.  All I can think of is that it somehow became empty or
mangled.
On Aug 19, 2007, at 11:36 PM, Michael Barton wrote:
> On 8/19/07 8:32 PM, "William Kyngesburye" <woklist at kyngchaos.com>
> wrote:
>> It was meant to be run from the makefile.  So just "make" and it
>> should work.  The makefile does the swig stuff.  Then runs "python
>> setup.py build".  Also, before running make, set the shell PATH to
>> include wxpython - for the 2.8.4 version I just installed today that
>> would be:
>> export PATH="/usr/local/lib/wxPython-unicode-2.8.4.2/bin:$PATH"
> I tried this but got the error...
> cmb-MBP:~/grass_dev/grass6/gui/wxpython/display_driver cmbarton$ make
> make: *** No targets.  Stop.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
More information about the grass-gui mailing list
