[GRASS-dev] Re: [GRASSGUI] Re: wxgrass won't work - how to set up digitization?
Martin Landa landa.martin at gmail.com
Fri Aug 24 04:05:35 EDT 2007
2007/8/22, Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
> > > Does this mean we will have mission-critical elements (such as
> > > digitiation) in C++ ?
> > in C++ is written only minimalistic display driver (library) for
> > digitization tool which draws vector elements on map canvas. This
> > library is used only for rendering purposes (question of speed).
> Do you mean the actual rendering, or retrieving the vector data to be
> rendered?
Sorry, I mean retrieving the vector data to be rendered...
Regards, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
More information about the grass-gui mailing list
