[GRASSGUI] CLI working again
William Kyngesburye woklist at kyngchaos.com
Fri Jun 8 10:15:33 EDT 2007
I've been meaning to ask about wxgrass and CLI stuff - you're
obviously working on a GUI psuedo-terminal for running commands the
old-fashioned CLI way.  I take it there is/will be no need for
something like 'grass-xterm-wrapper', and any place that the TclTk
GUI used that this pseudo terminal will work in wxgrass?
PS. did you ever get a chance to try my Terminal-enabled version of
grass-xterm-wrapper?  I've been lazy in committing it, so you'd have
to dig it out of the email, or maybe I should just commit it
anyways.  It's in my binaries and I haven't heard of any problems yet...
On Jun 6, 2007, at 3:12 PM, Michael Barton wrote:
> I got the CLI for wxgrass working again. You can type in any
> command (GRASS or shell).
> Non-GRASS commands will simply be passed to the shell.
> GRASS commands without arguments (e.g. g.region) will open their
> properties dialogs for non-display commands. d.* commands without
> arguments will add a layer to the GUI layer tree and open their
> respective properties dialog (e.g., d.rast).
> GRASS commands with arguments (e.g., g.region rast=elevation.10m)
> will be passed to the GRASS command shell for processing. d.*
> commands with arguments (e.g., d.rast elevation.10m) will display
> their results in the currently selected map display. Multiple
> display commands separated by commas will send overlaying graphic
> results to the current map display (e.g., d.rast elevation.
> 10m,d.vect roads color=red).
> Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
More information about the grass-gui mailing list
