[GRASSGUI] Using Python -t ?
Brad Douglas rez at touchofmadness.com
Sat Mar 24 04:13:09 EDT 2007
This would also be in keeping with GRASS C formatting guidelines.  The
closer we can keep the "look" between them, the better the readability.
Once the Python code matures, it would be ideal that someone write up a
SUBMITTING_PYTHON document before it gets committed back to the main
tree for production.
On Mon, 2007-03-19 at 22:31 -0500, Daniel Calvelo wrote:
> My vote for 4-space indentation, as this is emacs python-mode default.
> Daniel.
> On 3/19/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> > As some people seem to have trouble with indentation, I'd like to
> > suggest that the wxgrass script should be changed to use -t, or even
> > -t -t:
> >        -t     Issue  a  warning  when  a source file mixes tabs and spaces for
> >               indentation in a way that makes it depend on the worth of a  tab
> >               expressed  in  spaces.   Issue an error when the option is given
> >               twice.
> > Beyond that, we should agree upon a common indentation setting (number
> > of columns, and whether to use tabs or spaces). As Python determines
> > nesting based upon indentation, this isn't just a stylistic issue.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
More information about the grass-gui mailing list
