[GRASSGUI] qgis interface alike
William Kyngesburye woklist at kyngchaos.com
Mon Mar 26 10:05:14 EDT 2007
On Mar 26, 2007, at 4:27 AM, Jachym Cepicky wrote:
> Hi,
> costumized toolboxes (or module menus) are required by some users.
> I suggest:
> 1) create $HOME/.grass directory as directory for user settings
> 2) introduce another environment variabl $GISRCDIR (or similar)
> 3) create $GISRCDIR/gui
> 3) create $GISRCDIR/gui/custom
> 4) custom menus could be simple text (csv) or XML files stored in
> jachym
This gets into something I've been working on in the OSX build
system.  A user configuration dir.  Before anyone sets anything that
may be hard to change in the future, that $HOME/.grass (is that what
you intend GISRCDIR to be?) should be configurable during the build,
with appropriate defaults per platform.
For OSX, that would be $HOME/Library/GRASS, at least.  I already have
that in the OSX app build, and extended further by adding a GRASS
version: $HOME/Library/GRASS/6.3.  Currently, user addon modules are
stored here in "Modules".
Linux platforms could be ~/.grass.  Windows would probably be
different, though similar to OSX - somewhere in a user's home
preferences/config dir, whatever that is.
> 2007/3/26, Moritz Lennert <mlennert at club.worldonline.be>:
>> On 25/03/07 21:11, Daniel Calvelo wrote:
>> > On 3/25/07, Michael Barton <michael.barton at asu.edu> wrote:
>> GIS.
>> >> What might make more sense, in terms of flexibility, is to make
>> selected
>> >> GRASS commands also available (i.e., beyond the complex menu
>> >> hierarchy) via
>> >> a graphical 'tool box', as Trevor Wiens has suggested. Since
>> trying to
>> >> create a tool box for all 300+ commands would result in an
>> interface as
>> >> complicated as the menus themselves, maybe we could make a tool
>> box that
>> >> lets users 'plug in' or remove different command groups (e.g.,
>> >> hydrology or
>> >> terrain).
>> > That's what I meant by "Can the qgis plugin interface make sense
>> as a
>> > "quick toolbox" alongside the heavier wxgui?". My concern is
>> whether
>> > and how that would confuse users (especially newcomers) instead of
>> > giving them a gentler learning curve.
>> > I like the idea of having task-related or thematic groupings.
>> Another
>> > fine idea from Radim is the building of the command icons with a
>> very
>> > simple symbology; that might help making those thematic toolboxes
>> > friendlier.
>> I think that having the possibility of easily creating customized
>> toolboxes would be very helpful. This would allow us, for example, to
>> create a specific toolbox for a course grouping only those
>> commands you
>> really need, with reasonable defaults, etc. This would be a very nice
>> tool to ease entry into GRASS.
>> So, yes, I like Daniel's idea (and Radim's work ;-) ), since with
>> it the
>> user only has to edit text files and add a few images to create
>> such a
>> customised tool.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do
if you ARE a maniacally depressed robot?  No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
More information about the grass-gui mailing list
